Fuel Pump runs constantly., Relocated and rewired by PO. |
Crash207 |
Jun 8 2011, 05:10 PM
Newbie Group: Members Posts: 17 Joined: 23-May 11 From: United States Member No.: 13,108 Region Association: Rocky Mountains |
Hey guys.
73 1.7 D-Jet. 3 port Bosch fuel pump (now located under the fuel tank) runs constantly and is a bit loud. I read that it is supposed to run for 1-1.5 seconds and stop with key on engine off. Checked wiring and found it is wired directly to Fuse #8 on the fuse panel. Where should it be wired? Side note. Car sat for 5 years before i rescued it and the fuel pump had power but didn't run until i whacked it a few times. Thanks in advance, You guys are awesome and your expertise is much appreciated. |
Cap'n Krusty |
Jun 9 2011, 09:48 AM
If the pump is loud, it's been relocated, and you had to bang on it to get it to run, it already had 3 strikes against it. Loud: pinched inlet line, no rubber isolators, or bad bearings; stuck at some point, so you had to unstick it (it'll stick again, guaranteed); and relocated by someone who didn't know what he/she was doing. You're pressurizing lines that weren't meant to be pressurized, and there's a REAL good chance there are mismatched fittings and hoses hidden under the tank. The increased possibility of fire comes to mind.
Better get after it! The Cap'n |
Crash207 |
Jun 9 2011, 10:04 AM
I replaced all the fuel lines with pressure rated fuel hose but i need rubber isolators. Where would the original +12 volt power to fuel pump start or should i run new wires to the relay board?
Cap'n Krusty |
Jun 9 2011, 10:25 AM
I replaced all the fuel lines with pressure rated fuel hose but i need rubber isolators. Where would the original +12 volt power to fuel pump start or should i run new wires to the relay board? I was referring to the plastic lies through the tunnel, which were NOT designed to be under pressure. Actually, the '75-'76 cars used different plastic lines, which are rated for pressure. The Cap'n |
Lo-Fi Version | Time is now: 7th June 2024 - 08:06 AM |
