Exhaust stud, coming loose |
Elliot Cannon |
Jun 9 2011, 12:37 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I thought it was the nut that was coming loose. It turns out the stud will not stay tight resulting in a leak. What can I do to keep the stud in tight? Would it be too hot for locktight? What are my options other than tightening it down till it breaks. (IMG:style_emoticons/default/confused24.gif)
Attached thumbnail(s) |
Mike Bellis |
Jun 9 2011, 01:19 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Put a little JB Weld on the threads. The heat will not make the JB very strong but it should hold it in until you need to remove it.
Lo-Fi Version | Time is now: 29th May 2024 - 01:33 AM |
