Exhaust stud, coming loose |
Elliot Cannon |
Jun 9 2011, 12:37 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I thought it was the nut that was coming loose. It turns out the stud will not stay tight resulting in a leak. What can I do to keep the stud in tight? Would it be too hot for locktight? What are my options other than tightening it down till it breaks. (IMG:style_emoticons/default/confused24.gif)
Attached thumbnail(s) |
Cap'n Krusty |
Jun 9 2011, 01:51 PM
I thought it was the nut that was coming loose. It turns out the stud will not stay tight resulting in a leak. What can I do to keep the stud in tight? Would it be too hot for locktight? What are my options other than tightening it down till it breaks. (IMG:style_emoticons/default/confused24.gif) What engine? The Cap'n |
Elliot Cannon |
Jun 9 2011, 01:58 PM
I thought it was the nut that was coming loose. It turns out the stud will not stay tight resulting in a leak. What can I do to keep the stud in tight? Would it be too hot for locktight? What are my options other than tightening it down till it breaks. (IMG:style_emoticons/default/confused24.gif) What engine? The Cap'n Type IV |
Cap'n Krusty |
Jun 9 2011, 03:27 PM
I thought it was the nut that was coming loose. It turns out the stud will not stay tight resulting in a leak. What can I do to keep the stud in tight? Would it be too hot for locktight? What are my options other than tightening it down till it breaks. (IMG:style_emoticons/default/confused24.gif) What engine? The Cap'n Type IV Oh. One of the common issues here is the integrity of the boss on the head. Exhaust port cracks can intrude into the boss, or they can otherwise weaken the material in that area. I could attempt to install an insert for you, but it has been my experience that you have about a 50/50 chance of saving it. Used to be an easy fix, back when all the heads had a few miles on 'em. Now, not so much. There is NO easy magic fix. None. The Cap'n |
Lo-Fi Version | Time is now: 9th June 2024 - 09:46 PM |
