Exhaust stud, coming loose |
Elliot Cannon |
Jun 9 2011, 12:37 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I thought it was the nut that was coming loose. It turns out the stud will not stay tight resulting in a leak. What can I do to keep the stud in tight? Would it be too hot for locktight? What are my options other than tightening it down till it breaks. (IMG:style_emoticons/default/confused24.gif)
Attached thumbnail(s) |
HAM Inc |
Jun 10 2011, 02:02 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
And I should also add that it is not possible to use to much anti-seize down there. I slather it on the studs before I screw them in the heads and slather it all over the studs and the nuts. I prefer the copper based stuff as it handles the heat better than the silver permatex stuff.
I know NAPA sells copper based and I imagine that some other FLAPS do to. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:24 AM |
