Buzzing sound in my radio ? Need sound advise, Link added to a car audio DIY Education |
TC 914-8 |
Jun 13 2011, 10:30 PM
Senior Member Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
I was triing to clean up my center console the other day and moved my booster from inside the console to the outside, passenger side. once I did that I have a very loud and obnoxious buss in my raido. If I plug in and play my I Pod directly into the booster, no noise (IMG:style_emoticons/default/confused24.gif) . I have grounded the raido, booster, even went as far as grounding the sheilds of the RCA cables (and tried different cables) into the booster. That seemed to quiet it up a slight bit but still buzzes when the FM, CD is on.
I then went to raido Shack and picked up a noise supressor (inline capacitor) Still didn't help. I am begining to think Ignition or Alternator? Every thing was fine till I moved the booster from inside to the outside. This happened once before but not as severe, I just moved a few wires around and it went away. Any ideas?? Here is the link I found good for the DIY guy who knows enough to be dangerous. http://www.bcae1.com/ |
messix |
Jun 13 2011, 11:31 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
all of your audion equipment needs to be grounded at the same point. keep the rca cords away from any electric wires [do not bundle the power wires with the rca cords]
TC 914-8 |
Jun 13 2011, 11:34 PM
all of your audion equipment needs to be grounded at the same point. keep the rca cords away from any electric wires [do not bundle the power wires with the rca cords] Did that too (IMG:style_emoticons/default/headbang.gif) |
messix |
Jun 13 2011, 11:35 PM
all of your audion equipment needs to be grounded at the same point. keep the rca cords away from any electric wires [do not bundle the power wires with the rca cords] Did that too (IMG:style_emoticons/default/headbang.gif) does it do it when playing a cd? |
TC 914-8 |
Jun 13 2011, 11:40 PM
all of your audion equipment needs to be grounded at the same point. keep the rca cords away from any electric wires [do not bundle the power wires with the rca cords] Did that too (IMG:style_emoticons/default/headbang.gif) does it do it when playing a cd? YES Any time the RCA cables are plugged in and he engine is on it buzzes. FYI I also removed the Bosch-4 Sparks and went with stock Delco plugs. But I cant remember when I did what |
messix |
Jun 13 2011, 11:44 PM
all of your audion equipment needs to be grounded at the same point. keep the rca cords away from any electric wires [do not bundle the power wires with the rca cords] Did that too (IMG:style_emoticons/default/headbang.gif) does it do it when playing a cd? YES Any time the RCA cables are plugged in and he engine is on it buzzes. FYI I also removed the Bosch-4 Sparks and went with stock Delco plugs. But I cant remember when I did what you need to run resistor plugs and restistor plug wires. |
messix |
Jun 13 2011, 11:45 PM
all of your audion equipment needs to be grounded at the same point. keep the rca cords away from any electric wires [do not bundle the power wires with the rca cords] Did that too (IMG:style_emoticons/default/headbang.gif) does it do it when playing a cd? YES Any time the RCA cables are plugged in and he engine is on it buzzes. FYI I also removed the Bosch-4 Sparks and went with stock Delco plugs. But I cant remember when I did what you need to run resistor plugs and restistor plug wires. and check to see if any of the plug wires are close to any power wires |
TC 914-8 |
Jun 13 2011, 11:50 PM
all of your audion equipment needs to be grounded at the same point. keep the rca cords away from any electric wires [do not bundle the power wires with the rca cords] Did that too (IMG:style_emoticons/default/headbang.gif) does it do it when playing a cd? YES Any time the RCA cables are plugged in and he engine is on it buzzes. FYI I also removed the Bosch-4 Sparks and went with stock Delco plugs. But I cant remember when I did what you need to run resistor plugs and restistor plug wires. and check to see if any of the plug wires are close to any power wires Ya, Im sure they are all resistor type plugs and wires. Everything was fine and well til I moved the booster. Are you gonna be at the WCR? |
messix |
all of your audion equipment needs to be grounded at the same point. keep the rca cords away from any electric wires [do not bundle the power wires with the rca cords] Did that too (IMG:style_emoticons/default/headbang.gif) does it do it when playing a cd? YES Any time the RCA cables are plugged in and he engine is on it buzzes. FYI I also removed the Bosch-4 Sparks and went with stock Delco plugs. But I cant remember when I did what you need to run resistor plugs and restistor plug wires. and check to see if any of the plug wires are close to any power wires Ya, Im sure they are all resistor type plugs and wires. Everything was fine ad well til I moved the booster. Are you gonna be at the WCR? nope |
Lo-Fi Version | Time is now: 1st June 2024 - 12:22 AM |
