Buzzing sound in my radio ? Need sound advise, Link added to a car audio DIY Education |
TC 914-8 |
Jun 13 2011, 10:30 PM
Senior Member Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
I was triing to clean up my center console the other day and moved my booster from inside the console to the outside, passenger side. once I did that I have a very loud and obnoxious buss in my raido. If I plug in and play my I Pod directly into the booster, no noise (IMG:style_emoticons/default/confused24.gif) . I have grounded the raido, booster, even went as far as grounding the sheilds of the RCA cables (and tried different cables) into the booster. That seemed to quiet it up a slight bit but still buzzes when the FM, CD is on.
I then went to raido Shack and picked up a noise supressor (inline capacitor) Still didn't help. I am begining to think Ignition or Alternator? Every thing was fine till I moved the booster from inside to the outside. This happened once before but not as severe, I just moved a few wires around and it went away. Any ideas?? Here is the link I found good for the DIY guy who knows enough to be dangerous. http://www.bcae1.com/ |
Mike Bellis |
Jun 14 2011, 11:09 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Usually grounding the RCA's does more harm than good. You should only ground the radio side. But that can cause a ground loop and induce noise too.
I'm thinking you should move your booster (amp?) around and see if the noise level changes. If you have an old walkman. You can remove the tape head and extend the wires. Press play, put the head phones on and wave the head around your equipment. the head will pick up the source of your noise. You will hear the engine/alternator noise when you get the head close to the source. once you pin it down, make minor adjustments to the mounting, grounding , wiring until you hear a difference. I have a walkman setup for this from when I managed a car audio shop years ago. |
Lo-Fi Version | Time is now: 13th June 2024 - 09:04 AM |
