Buzzing sound in my radio ? Need sound advise, Link added to a car audio DIY Education |
TC 914-8 |
Jun 13 2011, 10:30 PM
Senior Member Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
I was triing to clean up my center console the other day and moved my booster from inside the console to the outside, passenger side. once I did that I have a very loud and obnoxious buss in my raido. If I plug in and play my I Pod directly into the booster, no noise (IMG:style_emoticons/default/confused24.gif) . I have grounded the raido, booster, even went as far as grounding the sheilds of the RCA cables (and tried different cables) into the booster. That seemed to quiet it up a slight bit but still buzzes when the FM, CD is on.
I then went to raido Shack and picked up a noise supressor (inline capacitor) Still didn't help. I am begining to think Ignition or Alternator? Every thing was fine till I moved the booster from inside to the outside. This happened once before but not as severe, I just moved a few wires around and it went away. Any ideas?? Here is the link I found good for the DIY guy who knows enough to be dangerous. http://www.bcae1.com/ |
nathansnathan |
Jun 15 2011, 06:42 AM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
Sounds to me like the problem is RADIO SHACK.
Get some real wires for signal. Anything from Radio Shack is going to give you problems. I wouldn't use their connectors, their wire even, I wouldn't use their solder or their soldering iron. -It's all built to ruin what you have. Go to a real electronics store and do it right or you'll forever be messing with it. I would use Noble brand insulated crimp connectors and an rca cable that wasn't made in china. |
windforfun |
Jun 15 2011, 09:30 AM
Senior Member Group: Members Posts: 1,822 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Sounds to me like the problem is RADIO SHACK. Get some real wires for signal. Anything from Radio Shack is going to give you problems. I wouldn't use their connectors, their wire even, I wouldn't use their solder or their soldering iron. -It's all built to ruin what you have. Go to a real electronics store and do it right or you'll forever be messing with it. I would use Noble brand insulated crimp connectors and an rca cable that wasn't made in china. Today's Radio Shack cables are very well rated. They have excellent bandwidth & good strain relief. Sounds to me, no pun intended, that you broke something. No shit. There's a bad connection somewhere. It might even be one of the jacks on your rigs. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:35 AM |
