> 914 four bolt pattern
lmcchesney
post Apr 16 2004, 12:16 PM
I have not found a complete source of accurate information on this topic.
The 914 is listed as having a 108mm four bolt pattern. What measures 108mm?
The offset of my empi's are about 100mm. Is this the true specs?
I have read else where that offset is a incorrect term. My use of offset is the distance from the inner surface of the wheel to the edge of the wheel rim projected down to the center line. Is this correct?
Wheels are measured as 15 x 6.5. How do you measure the with of the rim? Is it from outer (curb surface) to outer or within the bead to bead? If you were to place your ruler on the rims, from what point to what point would you measure?
What bolt dia and length and thread patern are standard? Ebay has a set of bolts that are 2 3/8" or 60mm in length and 1 1/2 inch or 36mm thead length. This allows about 50mm engaged inside the rotor hubs. What length should the bolts be inside the rotor hubs to be safely secured?
Thanks,
L. MCChesney
lmcchesney
post Apr 17 2004, 08:19 AM
Thanks Guys,
Also, what is the bolt size, 14mm?
Geoff, great news! The guys have done exactly that. Their in the process of selling their scout uniforms and are trying to unload some cases of popcorn to come up with the money. They have done extensive research, considering strength, weight and artistic value and came up with these:
They are going with the Battle Ax spinners.
They wanna make you proud!
L. McChensey
lmcchesney   914 four bolt pattern   Apr 16 2004, 12:16 PM
phantom914   108mm is the size of the imaginary circle that wou...   Apr 16 2004, 12:23 PM
DNHunt   I think the 4 bolt pattern is 4 X 130 mm, which is...   Apr 16 2004, 12:46 PM
lmcchesney   Phantom, is the 108, size of the imaginary circle....   Apr 16 2004, 01:25 PM
phantom914   L. It is diameter (commonly refered to as bolt ci...   Apr 16 2004, 02:05 PM
maf914   I think Dave is correct with 4 x 130. 130mm = 5...   Apr 16 2004, 02:20 PM
Dave_Darling   Yes, it's 4x130mm. Measure from one bolt cent...   Apr 16 2004, 02:49 PM
sanglee007   108 millimeters = 4.2519685 in 4x108mm = 4x4-1/4i...   Apr 17 2004, 12:25 AM
Bleyseng   yep, can't stand those heavy Bug rims on a 914...   Apr 17 2004, 02:59 AM
lmcchesney   Thanks Guys, Also, what is the bolt size, 14mm? ...   Apr 17 2004, 08:19 AM
Bleyseng   Isn't that the rim Mike Mueller is putting on ...   Apr 17 2004, 08:54 AM
lmcchesney   Geeze Geoff, I was joking. L. McC   Apr 17 2004, 09:39 AM
Mueller   yep, I'm putting rims similar to those on my 9...   Apr 17 2004, 11:06 AM
Revolution Wheels   The other important specification to check is the ...   Apr 17 2004, 02:58 PM
Mueller   since you are running GT flares, you have a few mo...   Apr 18 2004, 12:19 AM
lmcchesney   Thanks Mueller, I agree and that is the reason for...   Apr 18 2004, 11:40 AM
Mueller   What wheels are 108? Is it a typical FWD wheel? F...   Apr 18 2004, 12:30 PM
sanglee007   Mueller, 108 millimeters = 4.2519685 in 4x108mm =...   Apr 18 2004, 05:34 PM
lmcchesney   Thanks Mueller, It seems that I would be better se...   Apr 18 2004, 07:48 PM
- Lo-Fi Version Time is now: 11th July 2025 - 04:42 PM
