> Will not start, Valve clearance advice needed. modified 1.7
Haudiosolutions
post Jun 22 2011, 08:36 PM
Confusing issue which has been compounded by frequent torential rain and being on-call with 15+ hour days. Short back ground.... Steve and I were attempting to get my valves adjusted which was cut short by heavy rain. When I attempted to start the car later, nothing would happen. The battery seems good. Lights and accessories work. The starter can be manually jumped but I can't get action from the starter by using the ignition switch. The only thing I did out of the ordinary was absent mindedly leave the key switched one click up to unlock the wheel and left it that way for a while but not so far the fuel pump was running. I don't think that would cause an issue but figued I'd throw it in there. There are also two what looks like relays of some sort which I hope someone can clue me in on. The one in the pic is the one up top and the other one not pictured but looks very similar is wired to the starter. I should also add it's a standard points setup.
Thanks in advance for any suggestions. Saturday will be the earliest I could look at it unless I can bribe Steve with cash to get on it heheh (IMG:style_emoticons/default/poke.gif)
poorsche914
post Jun 22 2011, 09:47 PM
9fourteen
QUOTE(Haudiosolutions @ Jun 22 2011, 10:36 PM) *
... Saturday will be the earliest I could look at it unless I can bribe Steve with cash to get on it heheh (IMG:style_emoticons/default/poke.gif)
No bribe necessary. If this rain ever quits, I will remove the relay to the starter and see what happens. Might even do the DMM test to the battery.
If it ends up being the switch, that is an easy repair. If all years are the same, I should have a spare switch somewhere.
Got to get it (IMG:style_emoticons/default/driving.gif)
Prospectfarms
post Jun 22 2011, 10:35 PM
QUOTE(poorsche914 @ Jun 22 2011, 11:47 PM) *
From memory the switch versions go something like:
1970-71,72,73-74.
The 73 has a little plastic knob sticking out that the 72 does not, but they are otherwise identical. I have in my 72 today a 73 switch with it's appendage removed by 10 seconds of hacksaw. I have no info on the 71's or post 74's.
Haudiosolutions   Will not start   Jun 22 2011, 08:36 PM
Haudiosolutions   Another angle:   Jun 22 2011, 08:40 PM
poorsche914   ... Saturday will be the earliest I could look at ...   Jun 22 2011, 09:47 PM
Haudiosolutions   Thanks for the ideas! If the rain ever quits...   Jun 22 2011, 09:54 PM
Prospectfarms   ... Saturday will be the earliest I could look at...   Jun 22 2011, 10:35 PM
Haudiosolutions   Steve, are you working on it yet? It's only ra...   Jun 23 2011, 06:59 AM
mburkhart   I had a similar problem a few weeks ago where my b...   Jun 23 2011, 07:17 AM
poorsche914   Steve, are you working on it yet? It's only r...   Jun 23 2011, 11:05 AM
Drums66   .......I've had good fortune... with the hot s...   Jun 23 2011, 11:34 AM
Series9   Recently, I have been finding that high-resistence...   Jun 23 2011, 06:26 PM
Prospectfarms   Recently, I have been finding that high-resistenc...   Jun 23 2011, 09:07 PM
Haudiosolutions   I really hope it's that simple. I'm sure i...   Jun 23 2011, 09:23 PM
poorsche914   I may poke around a bit tomorrow if the weather is...   Jun 23 2011, 10:34 PM
Haudiosolutions   I may poke around a bit tomorrow if the weather i...   Jun 24 2011, 06:57 AM
detoxcowboy   Common and re-occuring issue of failing ignition s...   Jun 25 2011, 12:28 AM
poorsche914   OK... we are working on this now but while the eng...   Jun 25 2011, 07:55 AM
poorsche914   Start issue "possibly" resolved... found...   Jun 25 2011, 08:12 AM
Prospectfarms   Common and re-occuring issue of failing ignition ...   Jun 25 2011, 09:55 AM
poorsche914   Thanks for all the suggestions. The non-start prob...   Jun 25 2011, 10:37 AM
detoxcowboy   [quote name='detoxcowboy' post='1499768' date='Ju...   Jun 25 2011, 12:43 PM
Haudiosolutions   :WTF: Thanks Steve for your time and help. Cant ...   Jun 25 2011, 05:50 PM
poorsche914   Thanks Steve for your time and help. Cant thank yo...   Jun 25 2011, 06:27 PM
Haudiosolutions   Thanks Steve for your time and help. Cant thank y...   Jun 25 2011, 07:39 PM
detoxcowboy   Excuse me, outside of your topic,., Prospect Farms...   Jun 25 2011, 11:55 AM
poorsche914   detoxcowboy - we lucked out and found a wire had c...   Jun 25 2011, 12:14 PM
Tom   Great job guys, you're :first: Tom   Jun 25 2011, 07:36 PM
Dave_Darling   Valve clearances are 0.006" for both intake a...   Jun 26 2011, 12:52 PM
Haudiosolutions   Valve clearances are 0.006" for both intake ...   Jun 26 2011, 01:50 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:06 PM
