| bfrymire |
Aug 25 2009, 01:28 AM
Salsaholic ![]() ![]() ![]() Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Hello everyone, This is my thread to cover my conversion from Carbs to EFI. I will be using the Bitzracing CIS to EFI conversion kit, to replace the webers on the motor now, which is a 2.7l six. (And before anyone asks, I am not selling the carbs, yet. (IMG:style_emoticons/default/smile.gif) Want to make sure it works better before I unload the carbs.) (http://www.bitzracing.com) Ok, I am sure someone will ask why. Well, I autocross the car every month, and drive sometimes on the street. The carbs, due to sitting, tend to gunk up and require regular maintenance, and because, I am hoping the car will idle better, and just in general be more well behaved street driving. (Hey, it may even polute less. One can hope.) First step is to take it and have it tested on the dyno for a benchmark before any changes. (http://www.dynospotracing.com) The kit is fairly complete with good instructions. (You have a few parts to source yourself, easy to get.) As I go, I will provide more part numbers and details. Here's a picture of the parts kit including parts I sourced myself. |
| Dr Evil |
Apr 11 2011, 10:40 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
My 2.7 with CIS was nice. I almost had it dialed in...then I wrecked it. I still have the engine and it will be going into another car here soon.
The bus is getting CIS as well (IMG:style_emoticons/default/happy11.gif) |
| bfrymire |
Apr 12 2011, 12:03 AM
My 2.7 with CIS was nice. I almost had it dialed in...then I wrecked it. I still have the engine and it will be going into another car here soon. The bus is getting CIS as well (IMG:style_emoticons/default/happy11.gif) The fundamental design is good. EFI just makes it better. (IMG:style_emoticons/default/smile.gif) The ease of tuning really makes it great. (Of course all the other advantages are also good.) Here's some dyno results off the bitzracing site: "2.7 with CIS - 136hp at the wheels at 6200rpm 2.7 with EFI - 145hp at the wheels at 5800rpm before tuning 2.7 with EFI - 154hp at the wheels at 5800rpm after tuning" I am really curious what mine is going to end up at: I have headers, and modified E cams and european pistons. I am hoping for at least 165hp at the wheels. -- brett |
| bfrymire |
Apr 18 2011, 08:28 PM
Status update:
Fair amount of progress. Most of the sensors, are installed. The O2 bung is welded into header. Here's a picture of the install, and you can see the air intake installed. ![]() Ok. List of what to do: 1. Still need to plumb the fuel. Can't find a good location to mount the pump. I want something easy to access, but short fuel lines. 2. Re-install the header and install 02 sensor. 3. CIS linkage. This may be a problem. The motion of the carb linkage is wrong for the CIS. I may have to source some CIS linkage... 4. Wire the MS, and all the sensors. (This is the easy part. Should not take more than a couple of hours. In the words of Jeremy Clarkson, "how hard can it be?" (IMG:style_emoticons/default/biggrin.gif) ) Its getting close. I was hoping to be farther along. As usual, life got in the way. (IMG:style_emoticons/default/smile.gif) -- brett |
| rick 918-S |
Apr 18 2011, 08:52 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,239 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Status update: Fair amount of progress. Most of the sensors, are installed. The O2 bung is welded into header. Here's a picture of the install, and you can see the air intake installed. ![]() Ok. List of what to do: 1. Still need to plumb the fuel. Can't find a good location to mount the pump. I want something easy to access, but short fuel lines. 2. Re-install the header and install 02 sensor. 3. CIS linkage. This may be a problem. The motion of the carb linkage is wrong for the CIS. I may have to source some CIS linkage... 4. Wire the MS, and all the sensors. (This is the easy part. Should not take more than a couple of hours. In the words of Jeremy Clarkson, "how hard can it be?" (IMG:style_emoticons/default/biggrin.gif) ) Its getting close. I was hoping to be farther along. As usual, life got in the way. (IMG:style_emoticons/default/smile.gif) -- brett Nice work, I have CIS. I used a Volvo turbo pump and accumulator. I mounted it under tank. The Volvo has a pusher pump. Not the easiest to get to but if it's working correctly it's a done deal. |
| bfrymire |
Apr 18 2011, 09:58 PM
Nice work, I have CIS. I used a Volvo turbo pump and accumulator. I mounted it under tank. The Volvo has a pusher pump. Not the easiest to get to but if it's working correctly it's a done deal. Thanks Rick. I am not a professional mechanic, and sometimes I think I am a hack. (IMG:style_emoticons/default/smile.gif) So, the kind words are appreciated. Hum. You just mentioned something that I do not have. I did not put an accumulator in. Since, this is carbs, there just wasn't one. I understand that it's there as a reservoir for spikes in fuel demand. (For electronic guys, like a capacitor.) So, am I going to be at risk for fuel starvation? And the other omission, is the IAC. I still haven't figured out what to do on this. (I can adapt the stock unit, use a jeep IAC, or just a hand throttle. -- brett |
| ArtechnikA |
Jun 23 2011, 05:06 AM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
...I did not put an accumulator in. ... I understand that it's there as a reservoir for spikes in fuel demand.... So, am I going to be at risk for fuel starvation? No. And No. The accumulator (in conjunction with the check valve that's typically incorporated into a Bosch CIS pump) keeps pressure in the fuel loop to assist hot starts. Specifically, it keeps pressure up to resist fuel boiling in the lines following a hot shutdown. It's a good idea but you may be able to get away without one. If you start having hot-start issues, think about it. You do not need Porsche parts. There are hundreds of thousands of CIS-injected VW's and their parts for this will work just fine. Somewhere I even have the Earl's part numbers for the fittings and adapters you need to connect them with AN hose. If you're not using a Bosch pump, you'll need a separate high-pressure check valve. Earl's has those. |
| bfrymire |
Jun 23 2011, 01:20 PM
...I did not put an accumulator in. ... I understand that it's there as a reservoir for spikes in fuel demand.... So, am I going to be at risk for fuel starvation? No. And No. The accumulator (in conjunction with the check valve that's typically incorporated into a Bosch CIS pump) keeps pressure in the fuel loop to assist hot starts. Specifically, it keeps pressure up to resist fuel boiling in the lines following a hot shutdown. It's a good idea but you may be able to get away without one. If you start having hot-start issues, think about it. You do not need Porsche parts. There are hundreds of thousands of CIS-injected VW's and their parts for this will work just fine. Somewhere I even have the Earl's part numbers for the fittings and adapters you need to connect them with AN hose. If you're not using a Bosch pump, you'll need a separate high-pressure check valve. Earl's has those. Thanks! Good info. |
bfrymire Conversion from Carbs to CIS to EFI Aug 25 2009, 01:28 AM
Dr Evil Thanks for chronicling this :) I am interested. Aug 25 2009, 01:44 AM
bfrymire
... Aug 25 2009, 02:14 AM
shoguneagle Agree with the "Good Doc Evil". very in... Aug 25 2009, 02:12 AM
bfrymire
Agree with the "Good Doc Evil". very i... Aug 25 2009, 02:17 AM
Gint Cool! What do you plan to use for induction, ... Aug 25 2009, 08:04 AM
bfrymire
Cool! What do you plan to use for induction,... Aug 25 2009, 02:12 PM
wobbletop Subscribed. :D Aug 25 2009, 01:36 PM
turboman808 Why can't webers be converted to fuel injectio... Aug 25 2009, 01:57 PM
bfrymire
Why can't webers be converted to fuel injecti... Aug 25 2009, 02:16 PM
GeorgeRud Yes, please continue to chronicle your progress. ... Aug 25 2009, 02:23 PM
bfrymire
Yes, please continue to chronicle your progress. ... Aug 25 2009, 04:08 PM
turboman808 I was gonna say mount em like this but I think the... Aug 25 2009, 03:13 PM
bfrymire
I was gonna say mount em like this but I think th... Aug 26 2009, 02:15 AM
r_towle
I was gonna say mount em like this but I think th... Nov 17 2009, 10:30 PM
bfrymire Ok. Here's a picture in a 911 of what the fi... Aug 26 2009, 02:18 AM
number6 For those who didn't catch it, there was an Ex... Aug 26 2009, 03:25 AM
shoguneagle Would appreciate at least the date of the issue an... Aug 26 2009, 09:58 AM
wobbletop Could it be...
#167 Sep 2008
How to Add EFI to Yo... Aug 26 2009, 11:13 AM
bfrymire Status update:
Went and did the Dyno thing today.... Sep 4 2009, 11:10 PM
rktmn247 Progress? Very interested in this. Thanks for ta... Sep 16 2009, 10:51 PM
bfrymire
Progress? Very interested in this. Thanks for t... Sep 17 2009, 09:02 PM
bfrymire I am going to also post a bill of materials includ... Sep 17 2009, 09:02 PM
bfrymire I'm back....
Finally got some time to work on... Nov 17 2009, 01:06 AM
Mark Henry Very interesting!
Can I ask the size of the T... Nov 17 2009, 06:01 AM
bfrymire
Very interesting!
Can I ask the size of the ... Nov 17 2009, 08:29 PM
bfrymire Hello Guys,
Made some more progress. This conver... Nov 25 2009, 11:13 PM
Mark Henry I won't ask for his base maps:) Nov 17 2009, 10:26 PM
rktmn247 Next update please! :poke: Mar 5 2010, 08:47 PM
bfrymire
I was missing ... Mar 6 2010, 01:30 AM
rktmn247 You're welcome. Looking forward to the pics. Mar 6 2010, 01:55 AM
bfrymire
Still making slow progress. Here's the cutu... Mar 6 2010, 09:57 PM
pete-stevers interesting thread....
keep up the good work Mar 7 2010, 12:56 AM
Dr Evil This is great. Thanks for keeping us up to date :)... Mar 7 2010, 01:02 AM
rfuerst911sc Why do you think you have to install a pop-off val... Mar 7 2010, 05:54 AM
Al Meredith Rather than use Webers for Throtte Bodies why not ... Mar 7 2010, 12:08 PM
bfrymire
Made some more progress today. (Still need to... Mar 7 2010, 08:29 PM
rktmn247 Bump! Finished? :poke: Feb 12 2011, 07:53 PM
bfrymire You must be a mind reader! Amazing. I was go... Feb 13 2011, 01:31 AM
rktmn247 Looking forward to your update. Really want to se... Feb 13 2011, 03:02 AM
Gint :agree: Me too! Thanks for the bump. Feb 13 2011, 09:28 AM
sixnotfour Finally a 914 using this ,
MK was making these alu... Feb 13 2011, 09:46 AM
bfrymire
MK was making these al... Feb 13 2011, 01:00 PM
sixnotfour
MK was making these a... Feb 13 2011, 01:22 PM
bfrymire
[quote name='bfrymire' post='1430913' date='Feb 1... Feb 13 2011, 03:34 PM
GeorgeRud It's nice to see more information on this conv... Feb 13 2011, 01:40 PM
plastex http://www.bitzracing.com/gallery/Oscar_76...with_... Feb 13 2011, 09:16 PM
rktmn247
http://www.bitzracing.com/gallery/Oscar_76...with... Feb 13 2011, 10:22 PM
bfrymire
http://www.bitzracing.com/gallery/Oscar_76...with... Feb 13 2011, 10:28 PM
bandjoey
http://www.bitzracing.com/gallery/Oscar_76...with... Feb 13 2011, 11:40 PM
bfrymire Guys,
Finally sold the Alfa, and was able to clea... Mar 15 2011, 12:44 AM
bfrymire Made some more progress. Still going way too slow... Apr 10 2011, 05:00 PM
bfrymire Diagram of the fuel system. The fuel pump is a MS... Apr 11 2011, 02:41 PM
rktmn247 I love this thread. I am getting so many ideas. ... Feb 13 2011, 10:31 PM
JmuRiz Very cool stuff, can't wait to hear your impre... Apr 11 2011, 02:53 PM
bfrymire
Very cool stuff, can't wait to hear your impr... Apr 11 2011, 04:23 PM
TROJANMAN I didn't read through the entire thread, so I ... Apr 18 2011, 11:40 PM
bfrymire
I didn't read through the entire thread, so I... Apr 19 2011, 12:36 AM
Dr Evil Can you not rotate the throttle body to match the ... Apr 19 2011, 05:35 AM
bfrymire
Can you not rotate the throttle body to match the... Apr 19 2011, 12:27 PM
Dr Evil It is possible I am not getting it :)
Here is wha... Apr 19 2011, 12:33 PM
bfrymire
Here is wh... Apr 19 2011, 02:33 PM
Dr Evil
Here is w... Apr 19 2011, 02:49 PM
Almost ready to fire. Finished a... May 2 2011, 01:13 AM
Randal Looks like your build is progressing nicely. Good... Apr 19 2011, 01:14 PM
bfrymire
Looks like your build is progressing nicely. Goo... Apr 19 2011, 02:31 PM
rktmn247 Does it run? Did you make it to the auto x? :b... Jun 23 2011, 02:13 AM
bfrymire
Does it run? Did you make it to the auto x? :... Jun 23 2011, 01:19 PM
Series9 The two-year anniversary is rapidly approaching on... Jun 23 2011, 05:44 AM
bfrymire
The two-year anniversary is rapidly approaching o... Jun 23 2011, 01:21 PM
bfrymire Minor update. Fixed a few issues, and got the lin... Sep 10 2011, 08:25 PM
bfrymire Video.
Not sure how to do the imbedded vids: he... Sep 11 2011, 12:48 AM
GeorgeRud Sounds great! Can't wait to see the final... Sep 11 2011, 07:24 AM
Dr Evil :)
ReS1KjpH7oU Sep 12 2011, 06:27 PM
bfrymire Thanks. You will need to teach me. I have more vi... Sep 12 2011, 08:59 PM
Gint Sweet.
You just need to use the youtube tags with... Sep 13 2011, 09:02 PM
rktmn247 Great job seeing this through! Keep us posted... Sep 14 2011, 01:52 AM
bfrymire Just got back from an autocross. First one with t... Sep 18 2011, 03:10 PM
Jeffs9146 Can you give me some info on the wireing of your o... Sep 21 2011, 12:13 PM
bfrymire
Can you give me some info on the wireing of your ... Sep 21 2011, 01:19 PM
bfrymire
Can you give me some info on the wireing of your ... Sep 22 2011, 12:01 AM
Jeffs9146 :beer2:
Anything would help!
Are you going ... Sep 21 2011, 02:40 PM
bfrymire
:beer2:
Are you going... Sep 21 2011, 05:08 PM
Jeffs9146 That seems to be my problem.....nothing is matchin... Sep 22 2011, 01:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:52 PM |
