| Haudiosolutions |
Jun 22 2011, 08:36 PM
Member ![]() ![]() Group: Members Posts: 215 Joined: 19-October 10 From: Sevierville, TN Member No.: 12,284 Region Association: South East States |
Confusing issue which has been compounded by frequent torential rain and being on-call with 15+ hour days. Short back ground.... Steve and I were attempting to get my valves adjusted which was cut short by heavy rain. When I attempted to start the car later, nothing would happen. The battery seems good. Lights and accessories work. The starter can be manually jumped but I can't get action from the starter by using the ignition switch. The only thing I did out of the ordinary was absent mindedly leave the key switched one click up to unlock the wheel and left it that way for a while but not so far the fuel pump was running. I don't think that would cause an issue but figued I'd throw it in there. There are also two what looks like relays of some sort which I hope someone can clue me in on. The one in the pic is the one up top and the other one not pictured but looks very similar is wired to the starter. I should also add it's a standard points setup.
Thanks in advance for any suggestions. Saturday will be the earliest I could look at it unless I can bribe Steve with cash to get on it heheh (IMG:style_emoticons/default/poke.gif) Attached image(s)
| Series9 |
Jun 23 2011, 06:26 PM
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,453 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Recently, I have been finding that high-resistence terminals on the relay board are causing this problem.
I usually unplug and replug both 14-pin plugs on the relay board and see if that fixes it. If it does, you should get in there and clean those contacts because it will happen again. |
| Prospectfarms |
Jun 23 2011, 09:07 PM
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
Recently, I have been finding that high-resistence terminals on the relay board are causing this problem. I usually unplug and replug both 14-pin plugs on the relay board and see if that fixes it. If it does, you should get in there and clean those contacts because it will happen again. Makes sense. Thanks for the tip. Hot start relays are fine if you need them. But you are just adding a relay to another relay (the solenoid). I've seen so many ignition switches fail on cars with and without additional starter relays, and I've seen a couple of failed relays. So I'm not convinced they help that much. |
| Haudiosolutions |
Jun 23 2011, 09:23 PM
I really hope it's that simple. I'm sure it's something simple and it isn't like I've got a rod sticking through my case but it's annoying none the less. Especially since I'm currently no where near it. I hope the weather holds off on Saturday so I can find the problem if Steve doesn't stumble over it first
| poorsche914 |
Jun 23 2011, 10:34 PM
9fourteen ![]() ![]() ![]() ![]() Group: Members Posts: 3,151 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
I may poke around a bit tomorrow if the weather is clear. Will let you know.
(IMG:style_emoticons/default/idea.gif) |
Haudiosolutions Will not start Jun 22 2011, 08:36 PM
Haudiosolutions Another angle: Jun 22 2011, 08:40 PM
poorsche914 ... Saturday will be the earliest I could look at ... Jun 22 2011, 09:47 PM
Haudiosolutions Thanks for the ideas! If the rain ever quits... Jun 22 2011, 09:54 PM
Prospectfarms
... Saturday will be the earliest I could look at... Jun 22 2011, 10:35 PM
Haudiosolutions Steve, are you working on it yet? It's only ra... Jun 23 2011, 06:59 AM
mburkhart I had a similar problem a few weeks ago where my b... Jun 23 2011, 07:17 AM
poorsche914 Steve, are you working on it yet? It's only r... Jun 23 2011, 11:05 AM
Drums66 .......I've had good fortune... with the hot s... Jun 23 2011, 11:34 AM
Haudiosolutions
I may poke around a bit tomorrow if the weather i... Jun 24 2011, 06:57 AM
detoxcowboy Common and re-occuring issue of failing ignition s... Jun 25 2011, 12:28 AM
poorsche914 OK... we are working on this now but while the eng... Jun 25 2011, 07:55 AM
poorsche914 Start issue "possibly" resolved... found... Jun 25 2011, 08:12 AM
Prospectfarms
Common and re-occuring issue of failing ignition ... Jun 25 2011, 09:55 AM
poorsche914 Thanks for all the suggestions.
The non-start prob... Jun 25 2011, 10:37 AM
detoxcowboy
[quote name='detoxcowboy' post='1499768' date='Ju... Jun 25 2011, 12:43 PM
Haudiosolutions :WTF:
Thanks Steve for your time and help. Cant ... Jun 25 2011, 05:50 PM
poorsche914 Thanks Steve for your time and help. Cant thank yo... Jun 25 2011, 06:27 PM
Haudiosolutions
Thanks Steve for your time and help. Cant thank y... Jun 25 2011, 07:39 PM
detoxcowboy Excuse me, outside of your topic,., Prospect Farms... Jun 25 2011, 11:55 AM
poorsche914 detoxcowboy - we lucked out and found a wire had c... Jun 25 2011, 12:14 PM
Tom Great job guys, you're :first:
Tom Jun 25 2011, 07:36 PM
Dave_Darling Valve clearances are 0.006" for both intake a... Jun 26 2011, 12:52 PM
Haudiosolutions
Valve clearances are 0.006" for both intake ... Jun 26 2011, 01:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:25 PM |
