Vac Advance Unit, Testing |
76-914 |
Jun 28 2011, 07:42 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,512 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Is there a proper test for the dizzy vac adv unit? i.e., how many pounds vac and how long should it hold. Also, what about the retard side; the same?
76-914 |
Jun 28 2011, 11:45 AM
When I pulled on the advance side(I refuse to say sucked) the armature would move but it would not hold a vacuum. I can't squeeze the trigger fast enough to produce a measurable reading and it won't hold with my tongue, either. The retard side produces no movement at all. So it sounds as if it might be dead. Next question; is this part still available?
underthetire |
Jun 28 2011, 12:00 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
When I pulled on the advance side(I refuse to say sucked) the armature would move but it would not hold a vacuum. I can't squeeze the trigger fast enough to produce a measurable reading and it won't hold with my tongue, either. The retard side produces no movement at all. So it sounds as if it might be dead. Next question; is this part still available? I probably have a couple good ones laying around. It should hold a vacuum for quite some time. |
Lo-Fi Version | Time is now: 11th June 2024 - 11:09 PM |
