> air fuel ratio meters, Anyone have much experience using these on D-Jet
914Mels
post Jul 4 2011, 02:07 PM
(IMG:style_emoticons/default/sawzall-smiley.gif) I'm looking to fine tune the injection on my '70 914 and am considering a LM-1 meter to take out the guess work. Has anyone done much work with one of these? Or suggest a different model meter?
Mike Bellis
post Jul 4 2011, 03:57 PM
Resident Electrician
The LM-1 is a good unit. AEM and Autometer make them too with gauges to mount on the dash. Not much fine tuning can be done on early FI systems. You can tune it but not fine tune it. The system runs on internal fuel maps and they are not accessible.
914Mels
post Jul 4 2011, 04:56 PM
QUOTE(kg6dxn @ Jul 4 2011, 02:57 PM) *
Thanks for the reply, I wasn't sure who would be here on the 4th. The 914 monkey on my back won't let up, holiday or not. I want to fool the ICU, fuel pressure up or down, experiment with some variable resistors for the temp senders to get closer to a better mixture. I'm hoping to "see" where the engines at and not create any problems just randomly modifing and hoping for a improvement.
914Mels   air fuel ratio meters   Jul 4 2011, 02:07 PM
kg6dxn   The LM-1 is a good unit. AEM and Autometer make th...   Jul 4 2011, 03:57 PM
914Mels   The LM-1 is a good unit. AEM and Autometer make t...   Jul 4 2011, 04:56 PM
Dave_Darling   Heh, the system doesn't even rely on fuel maps...   Jul 4 2011, 04:23 PM
Strudelwagon   Heh, the system doesn't even rely on fuel map...   Jul 4 2011, 05:56 PM
brant   I've used an LM-1 to adjust MPS units to fit t...   Jul 4 2011, 05:45 PM
914Mels   I've used an LM-1 to adjust MPS units to fit ...   Jul 4 2011, 06:00 PM
914_teener   I've used an LM-1 to adjust MPS units to fit...   Jul 5 2011, 11:03 AM
914Mels   [quote name='914Mels' post='1504455' date='Jul 4 ...   Jul 5 2011, 11:38 AM
brant   its been done a lot but the wideband will tell you...   Jul 4 2011, 06:00 PM
914Mels   its been done a lot but the wideband will tell yo...   Jul 4 2011, 06:36 PM
ConeDodger   Remember to sample under load. Neutral revving num...   Jul 4 2011, 08:40 PM
sean_v8_914   LM1 can be found at a discount since they came out...   Jul 5 2011, 11:22 AM
Maltese Falcon   Mike, I'm using the unit from Nordskog Instrum...   Jul 5 2011, 09:38 PM
brant   nordskog makes some good stuff and their customer-...   Jul 5 2011, 10:59 PM
914Mels   I like your dash install, I'm not sure I want ...   Jul 6 2011, 05:44 PM
kg6dxn   I like your dash install, I'm not sure I want...   Jul 6 2011, 07:42 PM
914_teener   I like your dash install, I'm not sure I wan...   Jul 6 2011, 11:17 PM
Mark Henry   Just an FYI this is the JAW wideband, it's a D...   Jul 7 2011, 09:21 AM
Bleyseng   Factory Djet is close enough for a hydro cam 914.....   Jul 7 2011, 11:25 AM
914_teener   Factory Djet is close enough for a hydro cam 914....   Jul 7 2011, 03:56 PM
914Mels   Factory Djet is close enough for a hydro cam 914...   Jul 7 2011, 07:14 PM
914Mels   Sounds like you've done this once or twice.   Jul 7 2011, 11:31 AM
brant   It may not be where the factory set the MPS.. for...   Jul 7 2011, 12:55 PM
Bleyseng   It may not be where the factory set the MPS.. fo...   Jul 7 2011, 07:58 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:02 AM
