> air fuel ratio meters, Anyone have much experience using these on D-Jet
914Mels
post Jul 4 2011, 02:07 PM
(IMG:style_emoticons/default/sawzall-smiley.gif) I'm looking to fine tune the injection on my '70 914 and am considering a LM-1 meter to take out the guess work. Has anyone done much work with one of these? Or suggest a different model meter?
Dave_Darling
post Jul 4 2011, 04:23 PM
914 Idiot
Heh, the system doesn't even rely on fuel maps at all! It uses the amount of time for an electric current to induce a current in another coil of wire (inductive coupling) as the basic metering time!
Read up at http://members.rennlist.com/pbanders -- Brad Anders has a lot of D-jet info, including suggestions about ways that it can be tweaked and possibly (if you're lucky) tuned.
--DD
Strudelwagon
post Jul 4 2011, 05:56 PM
QUOTE(Dave_Darling @ Jul 4 2011, 03:23 PM) *
--DD
When I got my 2.0 a few years ago the PO had installed a little reostat with toggle switch that I believe can richen or lean out the fuel. Some old autocrosser black magic??
Wired directly to the ECU.
SW
914Mels   air fuel ratio meters   Jul 4 2011, 02:07 PM
kg6dxn   The LM-1 is a good unit. AEM and Autometer make th...   Jul 4 2011, 03:57 PM
914Mels   The LM-1 is a good unit. AEM and Autometer make t...   Jul 4 2011, 04:56 PM
Dave_Darling   Heh, the system doesn't even rely on fuel maps...   Jul 4 2011, 04:23 PM
Strudelwagon   Heh, the system doesn't even rely on fuel map...   Jul 4 2011, 05:56 PM
brant   I've used an LM-1 to adjust MPS units to fit t...   Jul 4 2011, 05:45 PM
914Mels   I've used an LM-1 to adjust MPS units to fit ...   Jul 4 2011, 06:00 PM
914_teener   I've used an LM-1 to adjust MPS units to fit...   Jul 5 2011, 11:03 AM
914Mels   [quote name='914Mels' post='1504455' date='Jul 4 ...   Jul 5 2011, 11:38 AM
brant   its been done a lot but the wideband will tell you...   Jul 4 2011, 06:00 PM
914Mels   its been done a lot but the wideband will tell yo...   Jul 4 2011, 06:36 PM
ConeDodger   Remember to sample under load. Neutral revving num...   Jul 4 2011, 08:40 PM
sean_v8_914   LM1 can be found at a discount since they came out...   Jul 5 2011, 11:22 AM
Maltese Falcon   Mike, I'm using the unit from Nordskog Instrum...   Jul 5 2011, 09:38 PM
brant   nordskog makes some good stuff and their customer-...   Jul 5 2011, 10:59 PM
914Mels   I like your dash install, I'm not sure I want ...   Jul 6 2011, 05:44 PM
kg6dxn   I like your dash install, I'm not sure I want...   Jul 6 2011, 07:42 PM
914_teener   I like your dash install, I'm not sure I wan...   Jul 6 2011, 11:17 PM
Mark Henry   Just an FYI this is the JAW wideband, it's a D...   Jul 7 2011, 09:21 AM
Bleyseng   Factory Djet is close enough for a hydro cam 914.....   Jul 7 2011, 11:25 AM
914_teener   Factory Djet is close enough for a hydro cam 914....   Jul 7 2011, 03:56 PM
914Mels   Factory Djet is close enough for a hydro cam 914...   Jul 7 2011, 07:14 PM
914Mels   Sounds like you've done this once or twice.   Jul 7 2011, 11:31 AM
brant   It may not be where the factory set the MPS.. for...   Jul 7 2011, 12:55 PM
Bleyseng   It may not be where the factory set the MPS.. fo...   Jul 7 2011, 07:58 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:30 PM
