| 914Mels |
Jul 4 2011, 02:07 PM
Member ![]() ![]() Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
(IMG:style_emoticons/default/sawzall-smiley.gif) I'm looking to fine tune the injection on my '70 914 and am considering a LM-1 meter to take out the guess work. Has anyone done much work with one of these? Or suggest a different model meter?
| brant |
Jul 4 2011, 06:00 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
its been done a lot
but the wideband will tell you how much to turn the knob AFR isn't like a boost knob there is a range and its not a wide one, where it will run right beyond that you loose HP, and on the lean side you do damage... really once you get it dialed in you should leave it alone. if you were going to tune for altitude, humidity (beyond the factory compensation) you would need the wideband to see what you were doing. brant |
| 914Mels |
Jul 4 2011, 06:36 PM
its been done a lot but the wideband will tell you how much to turn the knob AFR isn't like a boost knob there is a range and its not a wide one, where it will run right beyond that you loose HP, and on the lean side you do damage... really once you get it dialed in you should leave it alone. if you were going to tune for altitude, humidity (beyond the factory compensation) you would need the wideband to see what you were doing. brant That's the plan, get the modifications dialed in and replace the variables with some fixed resistors. Thanks to everyone who chimed in, I will have a beer in your honor. (IMG:style_emoticons/default/beer3.gif) Mike |
914Mels air fuel ratio meters Jul 4 2011, 02:07 PM
kg6dxn The LM-1 is a good unit. AEM and Autometer make th... Jul 4 2011, 03:57 PM
914Mels
The LM-1 is a good unit. AEM and Autometer make t... Jul 4 2011, 04:56 PM
Dave_Darling Heh, the system doesn't even rely on fuel maps... Jul 4 2011, 04:23 PM
Strudelwagon
Heh, the system doesn't even rely on fuel map... Jul 4 2011, 05:56 PM
brant I've used an LM-1 to adjust MPS units to fit t... Jul 4 2011, 05:45 PM
914Mels
I've used an LM-1 to adjust MPS units to fit ... Jul 4 2011, 06:00 PM
914_teener
I've used an LM-1 to adjust MPS units to fit... Jul 5 2011, 11:03 AM
914Mels
[quote name='914Mels' post='1504455' date='Jul 4 ... Jul 5 2011, 11:38 AM
ConeDodger Remember to sample under load. Neutral revving num... Jul 4 2011, 08:40 PM
sean_v8_914 LM1 can be found at a discount since they came out... Jul 5 2011, 11:22 AM
Maltese Falcon Mike, I'm using the unit from Nordskog Instrum... Jul 5 2011, 09:38 PM
brant nordskog makes some good stuff
and their customer-... Jul 5 2011, 10:59 PM
914Mels I like your dash install, I'm not sure I want ... Jul 6 2011, 05:44 PM
kg6dxn
I like your dash install, I'm not sure I want... Jul 6 2011, 07:42 PM
914_teener
I like your dash install, I'm not sure I wan... Jul 6 2011, 11:17 PM
Mark Henry Just an FYI this is the JAW wideband, it's a D... Jul 7 2011, 09:21 AM
Bleyseng Factory Djet is close enough for a hydro cam 914..... Jul 7 2011, 11:25 AM
914_teener
Factory Djet is close enough for a hydro cam 914.... Jul 7 2011, 03:56 PM
914Mels
Factory Djet is close enough for a hydro cam 914... Jul 7 2011, 07:14 PM
914Mels Sounds like you've done this once or twice. Jul 7 2011, 11:31 AM
brant It may not be where the factory set the MPS.. for... Jul 7 2011, 12:55 PM
Bleyseng
It may not be where the factory set the MPS.. fo... Jul 7 2011, 07:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:04 AM |
