OT: Motorcycle Guru's, Dual Carb Question |
saigon71 |
Jul 14 2011, 07:08 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
My Ninja 250 (don't knock it till you try it), won't idle without the choke on at least part way (after warmup). There is a definate flat spot through the low RPM range, but once you break through it, the bike winds out well. It has been this way since it rolled out of the shed after winter. I have some sea foam carb cleaner in the tank, and while I have not been riding it a lot, things have not really improved. Idle jet clog?
Thanks. |
TargaToy |
Jul 15 2011, 04:50 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
I actually use a single strand of copper wire out of a thicker wire bundle to chase the jets and since that's softer than brass, I've never encountered a scoring issue. And I generally go really easy into the jet with a twisting motion--real careful like. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 12:56 AM |
