OT: Motorcycle Guru's, Dual Carb Question |
saigon71 |
Jul 14 2011, 07:08 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
My Ninja 250 (don't knock it till you try it), won't idle without the choke on at least part way (after warmup). There is a definate flat spot through the low RPM range, but once you break through it, the bike winds out well. It has been this way since it rolled out of the shed after winter. I have some sea foam carb cleaner in the tank, and while I have not been riding it a lot, things have not really improved. Idle jet clog?
Thanks. |
TargaToy |
Jul 17 2011, 07:34 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
Sadly, I don't think draining the bowls is going to help you. Very tiny passages are likely plugged. The only way I know of to correct this is a thorough manual cleaning. You can do it. Just take your time and write stuff down/take pics for reference along the way in case you're nervous about putting things back together the way it came apart.
Another thing: Float bowl screw heads are soft. Make sure you use a good #2 screwdriver tip if you go to remove them. Once you bugger one up, it's a pain to remove the screw. A lot of times, I put a tip in a 1/4" socket and use a 1/4" drive wrench so that I can push into the screw hard with one hand while having the added leverage of the wrench to break them free. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:28 PM |
