> No spark!
Steve73
post Jul 18 2011, 02:12 AM
Photographer/Shade Tree Mechanic
I'm trying to bring a dead 914 back to life. I have done the usual prep work and have hooked up the electrical system. The car turns over strongly but there is no spark! No spark at the plugs, no spark at the coil. I have switched the coil out with one I had laying around but i'm not getting any better results. Could it be the voltage regulator located in the box where the fuel injected controls are? (mine has been converted to dual carbs BTW).
What should I try next?
Thanks in advance!
Steve73   No spark!   Jul 18 2011, 02:12 AM
corsepervita   How is the voltage up to the coil? The grounding? ...   Jul 18 2011, 03:52 AM
vsg914   Condensor   Jul 18 2011, 05:01 AM
Prospectfarms   Unlikely you have two bad coils. A good coil may n...   Jul 18 2011, 07:34 AM
Steve73   Unlikely you have two bad coils. A good coil may ...   Jul 18 2011, 10:39 AM
Drums66   ......Look at the grounding points, do them coil ?...   Jul 18 2011, 11:12 AM
codemasterlax   i have the same problem with mine not getting spar...   Sep 20 2011, 02:25 PM
Prospectfarms   i have the same problem with mine not getting spa...   Sep 20 2011, 02:36 PM
underthetire   i have the same problem with mine not getting spa...   Sep 20 2011, 02:44 PM
codemasterlax   i do have in a bosch coil but wht bushings   Sep 20 2011, 02:47 PM
underthetire   Grab the rotor and try and wiggle it side to side....   Sep 20 2011, 02:51 PM
codemasterlax   it does wiggle a lot but could tht also be because...   Sep 20 2011, 02:56 PM
underthetire   it does wiggle a lot but could tht also be becaus...   Sep 20 2011, 03:06 PM
codemasterlax   ok what part exactly do i need to replace on the d...   Sep 20 2011, 03:11 PM
underthetire   You would need to disassemble the dizzy, Press the...   Sep 20 2011, 03:53 PM
Cap'n Krusty   And where is he going to find bushings? The wrong...   Sep 20 2011, 05:05 PM
Prospectfarms   And where is he going to find bushings? The wron...   Sep 20 2011, 07:01 PM
underthetire   And where is he going to find bushings? The wron...   Sep 20 2011, 07:20 PM
Prospectfarms   And where is he going to find bushings? The wro...   Sep 20 2011, 09:12 PM
Steve73   Prospect Farms Thanks for asking about my 914. I ...   Sep 21 2011, 01:56 AM
underthetire   Prospect Farms Thanks for asking about my 914. I...   Sep 21 2011, 08:59 AM
Steve73   [quote name='Steve73' post='1542174' date='Sep 21...   Sep 25 2011, 09:53 PM
Steve73   I've got the engine running pretty well with t...   Oct 7 2011, 03:23 PM
vsg914   44 is the low side of the dwell. 47 would be bette...   Oct 7 2011, 04:13 PM
Prospectfarms   Per: Pelican: timing with Carbs. Set timing at 320...   Oct 7 2011, 10:25 PM
Steve73   Thanks everyone but I still need some advice about...   Oct 7 2011, 11:48 PM
Prospectfarms   Thanks everyone but I still need some advice abou...   Oct 8 2011, 09:48 PM
- Lo-Fi Version Time is now: 4th March 2026 - 02:21 PM
