Just about to give up, Any Ideas? |
matteyp |
Jul 22 2011, 06:38 PM
Nothing a little JB Weld can't fix... Group: Members Posts: 263 Joined: 8-June 09 From: WA Member No.: 10,450 Region Association: Pacific Northwest |
So Ive been having trouble with my car sputtering and backfiring and I just cannot figure it out. I have a 1.7 FI. When i rev the car under load it seems like it just has no power. Cars been timed correctly, went through everything and I still cannot figure it out. Hoses look ok, exhaust bolts seem to tighten but wont tighten completly. Not sure if this would cause all these problems or not. Could my injectors be clogged or fuel pressure be to low? Can someone go through a test procedure for this? I really don't want to have to spend another 3 or 4 hundred dollars on this if its just something simple. Thanks Guys
Matt |
JeffBowlsby |
Jul 22 2011, 07:56 PM
914 Wiring Harnesses Group: Members Posts: 8,548 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
This wont fix the sputtering or backfiring but may help the lack of power on acceleration.
1 drop of 30 wt on the felt pad under the rotor inside the shaft will lube the mechanical advance weights and should be done annually. |
Lo-Fi Version | Time is now: 15th June 2024 - 08:36 PM |
