> 2.0L Vac advance?, 039 905 205 A - '74 distributor
mgphoto
post Jul 23 2011, 01:25 PM
"If there is a mistake it will find me"
Hello,
I am trying to find out if this is the Vac advance unit for the 2.0 L '74 distributor, 039 905 205 A .
It has one vacuum chamber, can someone verify this is the correct unit on the correct side?
Thanks,
Mike
wingnut86
post Jul 23 2011, 05:03 PM
...boola la boo boola boo...
OK.
Per GH's Tech Tips 700 (G.Hussey, Pg. 79) (IMG:style_emoticons/default/beer.gif)
Check the Dizzy Vac. Adv. Mech . The arm should state "603" for the 74-76 2.0.
...and...
"...1974.5 - 1976 models had only vac. retard connected, and a 3-inch piece of vac hose connected to the advance port breathing to the wind. To test for proper operation, evacuate each port and observe that the points plate twists smoothly each way and holds. If the unit will not evacuate or vac leaks down, replace it..."
See if any of that helps.
Thank George (IMG:style_emoticons/default/aktion035.gif)
- Lo-Fi Version Time is now: 27th September 2026 - 07:13 PM
