| mgphoto |
Jul 23 2011, 01:25 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,500 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Hello,
I am trying to find out if this is the Vac advance unit for the 2.0 L '74 distributor, 039 905 205 A . It has one vacuum chamber, can someone verify this is the correct unit on the correct side? ![]() Thanks, Mike |
| mgphoto |
Jul 23 2011, 05:53 PM
Thanks Dave and George,
I see that the Bosch vac unit number is 1 237 122 603 as per PBAnders info, so the 603 on the vac unit arm is for the last 3 digits, I assume. The unit in my original photo has 265 as the number on the arm. Mike |
mgphoto 2.0L Vac advance? Jul 23 2011, 01:25 PM
wingnut86 ...this is the closest I found since I don't h... Jul 23 2011, 03:36 PM
mgphoto Hey Dave,
Thanks for responding, I saw that ad alo... Jul 23 2011, 04:22 PM
wingnut86 OK, you need an 039 905 271 for that distributor a... Jul 23 2011, 04:25 PM
wingnut86 Check the BMW distributors as well.
I believe the... Jul 23 2011, 04:35 PM
mgphoto Hey Dave,
I see what you are saying, but these are... Jul 23 2011, 04:44 PM
wingnut86 OK.
Per GH's Tech Tips 700 (G.Hussey, Pg. 79)... Jul 23 2011, 05:03 PM
TAP Mike,
Did you get it running? Injectors opening... Jul 23 2011, 07:18 PM
mgphoto
Mike,
Did you get it running? Injectors openin... Jul 23 2011, 08:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th September 2026 - 07:12 PM |
