| jpnovak |
Jul 25 2011, 03:26 PM
They call me "Nanoman" ![]() ![]() Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
Now that the engine is running I need to finalize some of the electrical connections. Notably, the alternator is near the top of the list.
Normally a regulated alternator has 5 connections 12V to battery D+ D- Df GND The Suby alternator is internally regulated so this elminates the Df wire. I need to connect up the D+ and D- to complete the voltage comparator. It looks like the blue D+ wire goes to Pin1 and I send 12V to Pin2 on the alternator. 12V becomes the effective D- wire to complete the circuit on Pin2. Basically, the current across the dash bulb that is a result of a difference in voltage between the alternator and the battery regulates the charge. At least, that is how I understand the wiring. Any thoughts? |
| Mike Bellis |
Jul 25 2011, 08:39 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Not a Subie but... On my rotary conversion I ditched the Mazda Alt in favor of a Chevy 1 wire. I did use a 175 amp Power Master but you can get a 80 chevy at your FLAPS cheap. Makes the conversion easier than using the original parts.
jpnovak Subaru Swap - Alternator wiring Jul 25 2011, 03:26 PM
BIGKAT_83 From the subaru factory manual......
Bob Jul 25 2011, 04:52 PM
jpnovak Thanks Bob but that is a much newer alternator tha... Jul 25 2011, 08:01 PM
strawman Here is a cut/paste from the 1998 Subaru Outback f... Jul 26 2011, 12:04 AM
strawman Just walked out in my garage and looked at my wiri... Jul 26 2011, 12:43 AM
jpnovak Geoff,
Thank you for the listing. The engine is ... Jul 26 2011, 07:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th November 2026 - 05:16 PM |
