> Diasater aversion for /6 owners, All oil leaks are not the same
SLITS
post Jul 26 2011, 07:54 AM
"This Utah shit is HARSH!"
Ok, finally got around to start checking The Grey Ghost for the upcoming endurance test to Ouray, CO. I've had an oil leak(s) I have been trying to trace down for sometime now. Thought it could have been, in order:
1.) Warped valve covers
2.) Improper tightening of chain housing covers or valve covers
3.) Cracked oil tank
4.) Only Dr. Ferry knows
Anyway, got the car on the lift on Sunday to look again. I looked and didn't find anything out of the ordinary (being old and blind, nothing is out of the ordinary).
Brought in a second set of eyes (no, not my glasses) and wella ... found something that caused extreme distress ....
There is a shaft in the chain housing that chain gear #1 (tensioner) sits on. The shaft had backed out of the housing and was only stopped by the head from completely backing out. If it had backed out, one can imagine this large piece of steel being wound up in the cam drive chain, sucked into the bottom of the case and ... well you might get the picture .. (didn't take any images)
It appears that this shaft is pushed into the boss and the backside is epoxied (factory) to seal it. Now whether the shaft is staked in the housing I cannot tell.
Anyway, I was able to push the shaft back into the housing and engage the boss in the front cover of the chain housing.
I am going to stake the shaft and then re-epoxy the back side to seal it and pray for the best (epoxy doesn't stick to oil very well). Boss does not appear to have been ovaled out.
I know that this would have let go somewhere around Beaver (IMG:style_emoticons/default/wub.gif), UT.
Anyway, one leak down ........ Game still on.
Not sure if this is a problem with /6s or just the 2.7.
SLITS   Diasater aversion for /6 owners   Jul 26 2011, 07:54 AM
gms   There is a shaft in the chain housing that chain ...   Jul 26 2011, 09:02 AM
J P Stein   A fairly common occurance with magnesium chain hou...   Jul 26 2011, 09:20 AM
SLITS   Thanks both of you for the replies; your advice is...   Jul 26 2011, 10:23 AM
sixnotfour   Common on CA. cars that run hot. your fix will pro...   Jul 26 2011, 12:34 PM
SLITS   Thanks Jeff ... Your Sogginess has a way with word...   Jul 26 2011, 03:32 PM
Cap'n Krusty   I wouldn't EVER use solid chain tensioners unl...   Jul 26 2011, 03:36 PM
SLITS   Thanks John ... I feel much better now.   Jul 26 2011, 04:33 PM
PRS914-6   If the hole is not egg shaped and still round, you...   Jul 26 2011, 04:51 PM
Root_Werks   I had a 75' 911S years back that the....driver...   Jul 26 2011, 05:08 PM
SLITS   Thanks Paul for the Loctite advice. And Dan, you ...   Jul 26 2011, 05:57 PM
sixnotfour   you are so slits, that will work.   Jul 26 2011, 08:03 PM
proto31   Hey, I'm pretty sure you should be using JB we...   Jul 26 2011, 11:34 PM
Dave_Darling   Are they SOLID tensioners, or just the older-style...   Jul 26 2011, 11:56 PM
SLITS   Dave ... they are solids, not early tensioners. ...   Jul 27 2011, 06:53 AM
J P Stein   I am still learning about common problems with S...   Jul 27 2011, 08:16 AM
SLITS   I am still learning about common problems with ...   Jul 27 2011, 09:07 AM
SLITS   Here's the temporary fix so it doesn't lea...   Jul 31 2011, 07:00 PM
- Lo-Fi Version Time is now: 11th July 2025 - 06:49 PM
