SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Ok, finally got around to start checking The Grey Ghost for the upcoming endurance test to Ouray, CO. I've had an oil leak(s) I have been trying to trace down for sometime now. Thought it could have been, in order:
1.) Warped valve covers 2.) Improper tightening of chain housing covers or valve covers 3.) Cracked oil tank 4.) Only Dr. Ferry knows Anyway, got the car on the lift on Sunday to look again. I looked and didn't find anything out of the ordinary (being old and blind, nothing is out of the ordinary). Brought in a second set of eyes (no, not my glasses) and wella ... found something that caused extreme distress .... There is a shaft in the chain housing that chain gear #1 (tensioner) sits on. The shaft had backed out of the housing and was only stopped by the head from completely backing out. If it had backed out, one can imagine this large piece of steel being wound up in the cam drive chain, sucked into the bottom of the case and ... well you might get the picture .. (didn't take any images) It appears that this shaft is pushed into the boss and the backside is epoxied (factory) to seal it. Now whether the shaft is staked in the housing I cannot tell. Anyway, I was able to push the shaft back into the housing and engage the boss in the front cover of the chain housing. I am going to stake the shaft and then re-epoxy the back side to seal it and pray for the best (epoxy doesn't stick to oil very well). Boss does not appear to have been ovaled out. I know that this would have let go somewhere around Beaver (IMG:style_emoticons/default/wub.gif), UT. Anyway, one leak down ........ Game still on. Not sure if this is a problem with /6s or just the 2.7. |
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,723 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
There is a shaft in the chain housing that chain gear #1 (tensioner) sits on. The shaft had backed out of the housing and was only stopped by the head from completely backing out. This usually happens when an engine is rebuilt and the builder puts chain housing in solvent and does not clean and reapply epoxy on the chain tension shafts. There is a good chance your housing hole has become oval, I would replace! |
Lo-Fi Version | Time is now: 11th July 2025 - 06:48 PM |
