Cambo |
Member ![]() ![]() Group: Members Posts: 122 Joined: 21-April 10 From: California Member No.: 11,641 Region Association: Northern California ![]() |
75 fuel injected 1.8. It's happened twice now. Pull into the gas station, fill up, then the car won't start. It will turn over but not catch. Both times, I waited a half hour and then it fired right up. Any common things I can check?
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
Assuming it is a starter heat issue the six cylinder engines (and starters) have the same glitch. Short of adding a relay I simply got tired of it and installed a high-torque starter... end of problem.
But truth be told the relay is a more elegant solution and saves your ignition switch's (start-position) contacts over time. |
Lo-Fi Version | Time is now: 4th July 2025 - 04:33 AM |
