JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Okay so I flat towed the LE down to Monterey CA 2 weeks ago. Car ran great while there. When I got home it was backfiring & running like crap. It has no power & won't stay running. The only strange thing was when I hooked it back up to bring it home. I got it all hooked up & forgot it was in gear (reverse). I put my Excursion in drive & had resistence. I didn't move more than 5 ft before I stopped. I went back & took it out of gear. I also had the ebrake on which I put down too. Started the car real quick & no problems. Turned it off & headed home. When I got unhooked at home it ran like crap (IMG:style_emoticons/default/WTF.gif)
So far I just checked all my hoses to be sure everything was on. I checked all my spark plug wires & they were as should be. I popped my distributor cap & saw nothing obviously wrong. Car doesn't want to stay running so I haven't pulled any spark plugs wires to see if it makes a difference. Just looking for some suggestions of things to check. It does have gas (IMG:style_emoticons/default/blink.gif) |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
My knee jerk response was your timing is off. But I'm not very smart and really bad at diagnosis.....so you can probably eliminate timing as the problem. (IMG:style_emoticons/default/blink.gif) Good luck Jamie, you've got almost a month to sort it out before you need to bring it to the BBQ.
Lo-Fi Version | Time is now: 10th June 2024 - 10:03 AM |
