| 913B |
Jul 31 2011, 08:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 864 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
So the continuing saga of fitting the SS heat exchangers continue. I somehow pulled out the heli coil repair on the exhaust stud. The coil measures 9.5mm OD.
I suppose I need to re-tap the hole with a step stud. So what size step stud should I use ?? M8 to (M10 or M11) ? Where would I find such a stud ? Is it do-able, drilling and tapping from under the engine ? How the heck am I going to keep the bit and tap straight and not F/up ? Man it never ends with old cars...... (IMG:style_emoticons/default/ar15.gif) Thanks in advance for everyones help !!!! I really appreciate it. (IMG:style_emoticons/default/beerchug.gif) ![]() ![]() ![]() |
| KaptKaos |
Jul 31 2011, 09:01 PM
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Not trying to 1-up Len. Just trying to add to the conversation. I certainly don't have the expertise to contradict Len.
porsche913b_sp Exhaust Stud Heli Coil Pulled Out Jul 31 2011, 08:16 PM
turnaround89 Its not that same area, however, i just had the th... Jul 31 2011, 08:22 PM
kg6dxn You need a time-sert. Search ebay. Way better than... Jul 31 2011, 08:23 PM
HAM Inc Your best bet now will be to get a M10x1.5 Time-Se... Jul 31 2011, 08:44 PM
iamchappy i went through this, i fixed it with a very stout ... Jul 31 2011, 08:50 PM
KaptKaos Be careful with the step-stud. You need to make s... Jul 31 2011, 08:57 PM
sean_v8_914 ouch, Hoffman laid that one out nicely. Jul 31 2011, 08:58 PM
sean_v8_914 I use a fixture t ensure the holes and tap threads... Jul 31 2011, 09:05 PM
Woody The picture looks like a time cert. It has a shoul... Jul 31 2011, 10:14 PM
porsche913b_sp dam that time sert pic from ebay looks like exactl... Jul 31 2011, 10:22 PM
porsche913b_sp dam that time sert pic from ebay looks like exactl... Jul 31 2011, 10:23 PM
Cap'n Krusty You won't like this, but read it anyway. Remo... Jul 31 2011, 10:46 PM
porsche913b_sp Dam it. I dont think I have the minimum 9/16 depth... Jul 31 2011, 11:16 PM
rjames
I did this a couple of years ago with the engine... Jul 31 2011, 11:16 PM
HAM Inc
Everything The Cap'n said is correct. I'v... Aug 1 2011, 07:06 AM
porsche913b_sp I don't drill too straight let alone run a tap... Aug 1 2011, 08:07 AM
HAM Inc Because of the proximity of the ex seat to the stu... Aug 1 2011, 08:36 AM
jcd914 I have never used E-Z LOK inserts so I can't r... Aug 1 2011, 01:40 PM
HAM Inc The M8 EZ lock O.D. is ~ the same size as the M10 ... Aug 1 2011, 01:51 PM
porsche913b_sp ok, so I checked it again, appears the depth of ho... Aug 1 2011, 05:56 PM
porsche913b_sp Hmm who sells the normal M8-1.25 exhaust stud ? Aug 1 2011, 06:03 PM
iamchappy Both myself and Phoenix914 have used the EZLOC wit... Aug 1 2011, 07:31 PM
Cap'n Krusty
Both myself and Phoenix914 have used the EZLOC wi... Aug 1 2011, 07:41 PM
porsche913b_sp I found this at http://www.mcmaster.com/#
93275A0... Aug 1 2011, 08:26 PM
porsche913b_sp
Both myself and Phoenix914 have used the EZLOC wi... Aug 1 2011, 08:31 PM
iamchappy Big flat screw driver. Used a punch to lock the Ez... Aug 1 2011, 08:40 PM
rjames
If you go slow, it should be fairly easy to dril... Aug 2 2011, 12:30 PM
Jake Raby This repair with the engine together requires surg... Aug 2 2011, 01:48 PM
Cap'n Krusty I think more luck than precision .................... Aug 2 2011, 06:16 PM
Woody I've done this same repair on my car and its b... Aug 3 2011, 06:54 AM
76-914
I've done this same repair on my car and its ... Aug 3 2011, 08:29 AM
Phoenix-MN
Both myself and Phoenix914 have used the EZLOC wi... Aug 3 2011, 07:45 AM
Bartlett 914
[quote name='iamchappy' post='1518033' date='Aug ... Aug 3 2011, 09:09 AM
iamchappy Fastenal carries them also.
I had to make an ext... Aug 3 2011, 07:54 AM
porsche913b_sp I am 1 lucky SOB. I was successful this weekend. T... Aug 7 2011, 10:21 PM
Cap'n Krusty
I am 1 lucky SOB. I was successful this weekend. ... Aug 8 2011, 08:22 AM
76-914 :thumbsup: Aug 8 2011, 08:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:33 PM |
