| 913B |
Jul 31 2011, 08:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 864 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
So the continuing saga of fitting the SS heat exchangers continue. I somehow pulled out the heli coil repair on the exhaust stud. The coil measures 9.5mm OD.
I suppose I need to re-tap the hole with a step stud. So what size step stud should I use ?? M8 to (M10 or M11) ? Where would I find such a stud ? Is it do-able, drilling and tapping from under the engine ? How the heck am I going to keep the bit and tap straight and not F/up ? Man it never ends with old cars...... (IMG:style_emoticons/default/ar15.gif) Thanks in advance for everyones help !!!! I really appreciate it. (IMG:style_emoticons/default/beerchug.gif) ![]() ![]() ![]() |
| HAM Inc |
Aug 1 2011, 07:06 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
QUOTE You won't like this, but read it anyway. Remove the head and have it welded, machined, drilled, and tapped. There's a REALLY good chance the threads and inserts are going away because the head is cracked. Be sure they fix ALL the cracks. Plan on spending a lot of money. BTW, there's NOTHING wrong with Helicoils if they're used as intended. They WON"T fix weakened or cracked base material, nor will any other brand/type of insert. The Cap'n Everything The Cap'n said is correct. I've seen a gazillion of the cracks he describes. That said, I examined the photo and it appears that you may just have a stripped boss. Hard to be 100% sure, but that is my hunch. And there is nothing wrong with Heli-coils if they are installed correctly. The biggest mistake is poor threading, regardless of the insert type. It's a touch task laying on your back to get it right. An unsteady hand will make a larger thread. The biggest drawback to the heli-coil is that it can be difficult to install in certain situations, like this one. If you have been living right and you do a perfect insert installation the unit may just stay put. If it doesn't you are facing removing the head. I can sell you a M10 x 8 step stud. My supply of the damn things is dwindling but I can spare one for a forum member in distress. It will be M10-1.5 x M8-1.25 I may be wrong about this, but I believe the EZloc requires a larger hole than the time-sert or heli-coil. If that is the case I would not consider it for this job as you are about out of boss material. A bit of advice that may sound counter intuitive, but trust me on this. Before you install whatever insert you decide to use slather both sides of that baby with copious amounts of copper anti-seize. Copper because it will stay put at higher temps without turning to paste like the silver kind. This will help keep the threads from corroding and increase the odds that the insert won't pull out over time. The Time-Sert will be much easier to install in this situation than the heli-coil. |
porsche913b_sp Exhaust Stud Heli Coil Pulled Out Jul 31 2011, 08:16 PM
turnaround89 Its not that same area, however, i just had the th... Jul 31 2011, 08:22 PM
kg6dxn You need a time-sert. Search ebay. Way better than... Jul 31 2011, 08:23 PM
HAM Inc Your best bet now will be to get a M10x1.5 Time-Se... Jul 31 2011, 08:44 PM
iamchappy i went through this, i fixed it with a very stout ... Jul 31 2011, 08:50 PM
KaptKaos Be careful with the step-stud. You need to make s... Jul 31 2011, 08:57 PM
sean_v8_914 ouch, Hoffman laid that one out nicely. Jul 31 2011, 08:58 PM
KaptKaos Not trying to 1-up Len. Just trying to add to the... Jul 31 2011, 09:01 PM
sean_v8_914 I use a fixture t ensure the holes and tap threads... Jul 31 2011, 09:05 PM
Woody The picture looks like a time cert. It has a shoul... Jul 31 2011, 10:14 PM
porsche913b_sp dam that time sert pic from ebay looks like exactl... Jul 31 2011, 10:22 PM
porsche913b_sp dam that time sert pic from ebay looks like exactl... Jul 31 2011, 10:23 PM
Cap'n Krusty You won't like this, but read it anyway. Remo... Jul 31 2011, 10:46 PM
porsche913b_sp Dam it. I dont think I have the minimum 9/16 depth... Jul 31 2011, 11:16 PM
rjames
I did this a couple of years ago with the engine... Jul 31 2011, 11:16 PM
porsche913b_sp I don't drill too straight let alone run a tap... Aug 1 2011, 08:07 AM
HAM Inc Because of the proximity of the ex seat to the stu... Aug 1 2011, 08:36 AM
jcd914 I have never used E-Z LOK inserts so I can't r... Aug 1 2011, 01:40 PM
HAM Inc The M8 EZ lock O.D. is ~ the same size as the M10 ... Aug 1 2011, 01:51 PM
porsche913b_sp ok, so I checked it again, appears the depth of ho... Aug 1 2011, 05:56 PM
porsche913b_sp Hmm who sells the normal M8-1.25 exhaust stud ? Aug 1 2011, 06:03 PM
iamchappy Both myself and Phoenix914 have used the EZLOC wit... Aug 1 2011, 07:31 PM
Cap'n Krusty
Both myself and Phoenix914 have used the EZLOC wi... Aug 1 2011, 07:41 PM
porsche913b_sp I found this at http://www.mcmaster.com/#
93275A0... Aug 1 2011, 08:26 PM
porsche913b_sp
Both myself and Phoenix914 have used the EZLOC wi... Aug 1 2011, 08:31 PM
iamchappy Big flat screw driver. Used a punch to lock the Ez... Aug 1 2011, 08:40 PM
rjames
If you go slow, it should be fairly easy to dril... Aug 2 2011, 12:30 PM
Jake Raby This repair with the engine together requires surg... Aug 2 2011, 01:48 PM
Cap'n Krusty I think more luck than precision .................... Aug 2 2011, 06:16 PM
Woody I've done this same repair on my car and its b... Aug 3 2011, 06:54 AM
76-914
I've done this same repair on my car and its ... Aug 3 2011, 08:29 AM
Phoenix-MN
Both myself and Phoenix914 have used the EZLOC wi... Aug 3 2011, 07:45 AM
Bartlett 914
[quote name='iamchappy' post='1518033' date='Aug ... Aug 3 2011, 09:09 AM
iamchappy Fastenal carries them also.
I had to make an ext... Aug 3 2011, 07:54 AM
porsche913b_sp I am 1 lucky SOB. I was successful this weekend. T... Aug 7 2011, 10:21 PM
Cap'n Krusty
I am 1 lucky SOB. I was successful this weekend. ... Aug 8 2011, 08:22 AM
76-914 :thumbsup: Aug 8 2011, 08:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:02 PM |
