> Exhaust Stud Heli Coil Pulled Out, Wou is me, Help! Correction Time Sert came out
913B
post Jul 31 2011, 08:16 PM
So the continuing saga of fitting the SS heat exchangers continue. I somehow pulled out the heli coil repair on the exhaust stud. The coil measures 9.5mm OD.
I suppose I need to re-tap the hole with a step stud.
So what size step stud should I use ?? M8 to (M10 or M11) ?
Where would I find such a stud ?
Is it do-able, drilling and tapping from under the engine ?
How the heck am I going to keep the bit and tap straight and not F/up ?
Man it never ends with old cars...... (IMG:style_emoticons/default/ar15.gif)
Thanks in advance for everyones help !!!! I really appreciate it.
Jake Raby
post Aug 2 2011, 01:48 PM
Engine Surgeon
This repair with the engine together requires surgical precision. It also requires a lot of luck.
porsche913b_sp   Exhaust Stud Heli Coil Pulled Out   Jul 31 2011, 08:16 PM
turnaround89   Its not that same area, however, i just had the th...   Jul 31 2011, 08:22 PM
kg6dxn   You need a time-sert. Search ebay. Way better than...   Jul 31 2011, 08:23 PM
HAM Inc   Your best bet now will be to get a M10x1.5 Time-Se...   Jul 31 2011, 08:44 PM
iamchappy   i went through this, i fixed it with a very stout ...   Jul 31 2011, 08:50 PM
KaptKaos   Be careful with the step-stud. You need to make s...   Jul 31 2011, 08:57 PM
sean_v8_914   ouch, Hoffman laid that one out nicely.   Jul 31 2011, 08:58 PM
KaptKaos   Not trying to 1-up Len. Just trying to add to the...   Jul 31 2011, 09:01 PM
sean_v8_914   I use a fixture t ensure the holes and tap threads...   Jul 31 2011, 09:05 PM
Woody   The picture looks like a time cert. It has a shoul...   Jul 31 2011, 10:14 PM
porsche913b_sp   dam that time sert pic from ebay looks like exactl...   Jul 31 2011, 10:22 PM
porsche913b_sp   dam that time sert pic from ebay looks like exactl...   Jul 31 2011, 10:23 PM
Cap'n Krusty   You won't like this, but read it anyway. Remo...   Jul 31 2011, 10:46 PM
porsche913b_sp   Dam it. I dont think I have the minimum 9/16 depth...   Jul 31 2011, 11:16 PM
rjames   I did this a couple of years ago with the engine...   Jul 31 2011, 11:16 PM
HAM Inc   Everything The Cap'n said is correct. I'v...   Aug 1 2011, 07:06 AM
porsche913b_sp   I don't drill too straight let alone run a tap...   Aug 1 2011, 08:07 AM
HAM Inc   Because of the proximity of the ex seat to the stu...   Aug 1 2011, 08:36 AM
jcd914   I have never used E-Z LOK inserts so I can't r...   Aug 1 2011, 01:40 PM
HAM Inc   The M8 EZ lock O.D. is ~ the same size as the M10 ...   Aug 1 2011, 01:51 PM
porsche913b_sp   ok, so I checked it again, appears the depth of ho...   Aug 1 2011, 05:56 PM
porsche913b_sp   Hmm who sells the normal M8-1.25 exhaust stud ?   Aug 1 2011, 06:03 PM
iamchappy   Both myself and Phoenix914 have used the EZLOC wit...   Aug 1 2011, 07:31 PM
Cap'n Krusty   Both myself and Phoenix914 have used the EZLOC wi...   Aug 1 2011, 07:41 PM
porsche913b_sp   I found this at http://www.mcmaster.com/# 93275A0...   Aug 1 2011, 08:26 PM
porsche913b_sp   Both myself and Phoenix914 have used the EZLOC wi...   Aug 1 2011, 08:31 PM
iamchappy   Big flat screw driver. Used a punch to lock the Ez...   Aug 1 2011, 08:40 PM
rjames   If you go slow, it should be fairly easy to dril...   Aug 2 2011, 12:30 PM
Jake Raby   This repair with the engine together requires surg...   Aug 2 2011, 01:48 PM
Cap'n Krusty   I think more luck than precision ....................   Aug 2 2011, 06:16 PM
Woody   I've done this same repair on my car and its b...   Aug 3 2011, 06:54 AM
76-914   I've done this same repair on my car and its ...   Aug 3 2011, 08:29 AM
Phoenix-MN   Both myself and Phoenix914 have used the EZLOC wi...   Aug 3 2011, 07:45 AM
Bartlett 914   [quote name='iamchappy' post='1518033' date='Aug ...   Aug 3 2011, 09:09 AM
iamchappy   Fastenal carries them also. I had to make an ext...   Aug 3 2011, 07:54 AM
porsche913b_sp   I am 1 lucky SOB. I was successful this weekend. T...   Aug 7 2011, 10:21 PM
Cap'n Krusty   I am 1 lucky SOB. I was successful this weekend. ...   Aug 8 2011, 08:22 AM
76-914   :thumbsup:   Aug 8 2011, 08:01 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:06 PM
