| tradisrad |
Aug 4 2011, 01:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I am looking for an upgrade to my front stock calipers and the "M" caliper for solid rotors seems to be a good choice. The car has a 19mm master cylinder and the braking could be better and instead of replacing the master cylinder with a 17mm I thought I'd upgrade the front calipers.
From what I can tell early 911/912 calipers for solid rotors will be a direct bolt on to the early 914 strut. I also think they use the same brake pad. Has any one done this or can someone confirm that they will be a direct bolt on and is the pad size the same? thanks -Rob |
SLITS Eric has to chime in ... I think the offset is dif... Aug 4 2011, 05:47 PM
ArtechnikA
I am looking for an upgrade to my front stock cal... Aug 4 2011, 05:48 PM
tradisrad My understanding of the 19mm master with the stock... Aug 4 2011, 06:22 PM
914Sixer Get a stock 17mm master cylinder and put some GOOD... Aug 4 2011, 08:21 PM
Eric_Shea
They bolt right on. Good choice? Same size pad... Aug 4 2011, 10:11 PM
brant the right pad makes stock calipers VERY VERY good.... Aug 4 2011, 10:23 PM
tradisrad Thanks for the replies.
I do have good pads, R4S, ... Aug 5 2011, 07:54 AM
Eric_Shea Not trying to sell a set of pads but... 914 brakes... Aug 5 2011, 07:24 PM
Dave_Darling Remember: Brakes stop the wheels.
TIRES stop the... Aug 5 2011, 09:14 PM
tradisrad Eric, I did pick up some rear pads last night. I a... Aug 6 2011, 08:52 AM
jmill
PMB seems to have good prices.
If he's got ... Aug 6 2011, 10:37 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:18 PM |
