| tradisrad |
Aug 4 2011, 01:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I am looking for an upgrade to my front stock calipers and the "M" caliper for solid rotors seems to be a good choice. The car has a 19mm master cylinder and the braking could be better and instead of replacing the master cylinder with a 17mm I thought I'd upgrade the front calipers.
From what I can tell early 911/912 calipers for solid rotors will be a direct bolt on to the early 914 strut. I also think they use the same brake pad. Has any one done this or can someone confirm that they will be a direct bolt on and is the pad size the same? thanks -Rob |
| SLITS |
Aug 4 2011, 05:47 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Eric has to chime in ... I think the offset is different and the rotor won't center in the caliper.
Early BMW calipers will bolt on an early strut and center correctly. There are threads about that "upgrade". To fit later cars, I remember the mounting ears have to be shaved 0.125" on the inside AFAIR. Don't remember the years of the Beemer either. |
tradisrad Early 911/912 "M" calipers Aug 4 2011, 01:34 PM
ArtechnikA
I am looking for an upgrade to my front stock cal... Aug 4 2011, 05:48 PM
tradisrad My understanding of the 19mm master with the stock... Aug 4 2011, 06:22 PM
914Sixer Get a stock 17mm master cylinder and put some GOOD... Aug 4 2011, 08:21 PM
Eric_Shea
They bolt right on. Good choice? Same size pad... Aug 4 2011, 10:11 PM
brant the right pad makes stock calipers VERY VERY good.... Aug 4 2011, 10:23 PM
tradisrad Thanks for the replies.
I do have good pads, R4S, ... Aug 5 2011, 07:54 AM
Eric_Shea Not trying to sell a set of pads but... 914 brakes... Aug 5 2011, 07:24 PM
Dave_Darling Remember: Brakes stop the wheels.
TIRES stop the... Aug 5 2011, 09:14 PM
tradisrad Eric, I did pick up some rear pads last night. I a... Aug 6 2011, 08:52 AM
jmill
PMB seems to have good prices.
If he's got ... Aug 6 2011, 10:37 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:17 PM |
