Need some help, Troubleshooting my car |
914curt |
Apr 13 2003, 10:09 PM
Newbie Group: Members Posts: 15 Joined: 12-February 03 From: Chicago, IL Member No.: 306 |
I am having trouble with my 914. I have a 1974 1.8L that is bored to a 2.0L with dual 40mm carbs on it, that is about all i know about the motor. I purchased the car with this engine in it and was told it had a 1.8 turned in to a 2.0. The problem i am having is that it has completlely run out of power it was running good last summer but at the end before i put it away for the winter it got really bad. it will not accelerate at all. But sometimes it does. it is intermitent. Today i tool it out and it ran fine at first and them went to crap. it had no power and was back firing like crazy. I have put a new ignition system in the car, and changed the plugs today. when i checked the plugs all of them looked good except cylinder three. It was completly black, like covered in oil. the rest of them looked great like they were supposed to be. after changing the plugs there was no difference in the performance in the car. i was thinking that the problem could be the rings in cylinder 3 but i am a very novice mechanic. this is my first time trouble shooting a car by myself. Could anybody give me some advice or ideas on what it could be or if i am right about the rings.
Curt |
sechszylinder |
Apr 14 2003, 07:47 AM
Member Group: Members Posts: 247 Joined: 9-April 03 From: /earth/europe/germany/berlin Member No.: 545 Region Association: None |
First i would check the compression of your engine with a compression meter, then i would check the valve clearance, cause carbs are very sensitive to misaligned valves.
After that have a look at your ignition (correct firing order, correct dwell angle). If everthing is o.k. i would guess that you have a problem with the fuel system. Perhaps the fuel pressure is to high or the float level is misaligned. Check your fuel pump carefully, if it's running all the time with the right fuel pressure. Benno |
Lo-Fi Version | Time is now: 12th June 2024 - 03:51 PM |
