> Early 911/912 "M" calipers, direct bolt on to a '70 914?
tradisrad
post Aug 4 2011, 01:34 PM
I am looking for an upgrade to my front stock calipers and the "M" caliper for solid rotors seems to be a good choice. The car has a 19mm master cylinder and the braking could be better and instead of replacing the master cylinder with a 17mm I thought I'd upgrade the front calipers.
From what I can tell early 911/912 calipers for solid rotors will be a direct bolt on to the early 914 strut. I also think they use the same brake pad.
Has any one done this or can someone confirm that they will be a direct bolt on and is the pad size the same?
thanks
-Rob
Eric_Shea
post Aug 5 2011, 07:24 PM
PMB Performance
Not trying to sell a set of pads but... 914 brakes are very well balanced. I like the same compunds front and rear.
Here's the bedding procedure:
http://www.pmbperformance.com/Bedding.html
- Lo-Fi Version Time is now: 2nd April 2026 - 12:18 PM
