Razorbobsr |
Member ![]() ![]() Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest ![]() |
Getting my car back from Porsche guy, drove 70 miles to home just fine. Get off interstate and engine stalls, hit key and nothing!!! Tach pegs at 7000 but no starter engagement, do have hot start kit. Car ran GREAT all the way home. Ideas? Help needed!! Thanks Bob
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
An easy way to cut the problem in half is:
Remove the large yellow wire from the starter solenoid and check for 12 volts between that wire and ground when trying to start. If you have 12 volts, then there is probably a starter solenoid problem. Gently tap the solenoid, hook up the yellow wire, and try again, sometimes the heat causes the solenoid to bind and not connect the batt to starter contacts. If greatly less than 12 volts, (Less than 9 volts), you have a connection problem between the key switch and the starter solenoid yellow wire. Possible ground problem also, check negative batt terminal and large ground strap at transmission. In case you are not aware, the solenoid does two things; moves the starter motor gear out to connect with the flywheel, and makes two electrical connnection with two large contacts to give the starter motor the voltage and current to turn the starter motor. Tom |
Lo-Fi Version | Time is now: 12th July 2025 - 10:54 AM |
