| grantsfo |
Jun 21 2011, 04:53 PM
Arrrrhhhh! ![]() ![]() ![]() ![]() Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Hey who else is coming for the fun at Nationals this year? This is my first one! whoo hoo! I have NRF ....Nationals Rookie Fever! (IMG:style_emoticons/default/piratenanner.gif)
I see J is signed up. Is Brit still planning to go? Any other teeners going to attend? https://www.motorsportreg.com/index.cfm/eve...A2D9F971EB7FA2B This post has been edited by grantsfo: Jun 21 2011, 04:54 PM |
| Britain Smith |
Aug 8 2011, 09:25 PM
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I was running the 22.0x16.10's Bias Ply in the rear, the new set-up will be 23.5x16x12's Radials.
The mass of the 18's are a bit of a deterrent. -Britain |
| J P Stein |
Aug 8 2011, 10:08 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I was running the 22.0x16.10's Bias Ply in the rear, the new set-up will be 23.5x16x12's Radials. The mass of the 18's are a bit of a deterrent. -Britain Some time back I had the opportunity to weigh a friends 275 X 40 X 17 A6s on 11 inch Kinessis (sp?). 44 lbs each. Our 16s with slicks were 32lbs. The fronts had an 8 lb difference each over our fronts. I suspect the 18 inch W/T combo weighs even more. Who needs 40 extra lbs of unsprung weight? Brit, weigh them 12" suckers after you get them mounted. |
| grantsfo |
Aug 15 2011, 11:08 AM
I was running the 22.0x16.10's Bias Ply in the rear, the new set-up will be 23.5x16x12's Radials. The mass of the 18's are a bit of a deterrent. -Britain Some time back I had the opportunity to weigh a friends 275 X 40 X 17 A6s on 11 inch Kinessis (sp?). 44 lbs each. Our 16s with slicks were 32lbs. The fronts had an 8 lb difference each over our fronts. I suspect the 18 inch W/T combo weighs even more. Who needs 40 extra lbs of unsprung weight? Brit, weigh them 12" suckers after you get them mounted. Boxster has ended up on 18x12 with a 315 rear and 18x10 with 295 front. Dang! thats what I run on the Z now, but I have 315 WHP in the Z. I have plans to move the Z to 335 R and 315 front next season. I'm sure those big wheels and tires make that wimpy little stock 2480 cc 175 WHP engine scream for mercy. But no denying national level results with that tire setup. |
grantsfo 2011 SCCA National Thread Jun 21 2011, 04:53 PM
BMXerror I will be there in Tom Berry's STX BMW (That... Jun 21 2011, 07:26 PM
grantsfo
I will be there in Tom Berry's STX BMW (That... Jun 22 2011, 10:00 AM
Joe Ricard Went last year, skipping this year. Maybe if in a... Jun 27 2011, 09:07 AM
J P Stein Last I spoke with Brit about the Nats he was runni... Jun 27 2011, 10:14 AM
grantsfo
Last I spoke with Brit about the Nats he was runn... Jun 27 2011, 02:06 PM
jjackson
Last I spoke with Brit about the Nats he was run... Jul 13 2011, 07:36 AM
Joe Ricard Maybe we can take up a collection to send Britt an... Jul 13 2011, 09:46 AM
J P Stein
. ..... even thou there is nothing type IV about... Jul 13 2011, 10:58 AM
Joe Ricard Without a doubt JP. The only fast 914 is a HIGHLY... Jul 13 2011, 01:13 PM
jjackson
Without a doubt JP. The only fast 914 is a HIGHL... Jul 13 2011, 06:29 PM
BMXerror Why can't it be a highly modified T4 914? Can ... Jul 13 2011, 07:01 PM
jjackson
Why can't it be a highly modified T4 914? Can... Jul 13 2011, 07:54 PM
grantsfo Im with you JJ lets get some 914's out there... Jul 15 2011, 01:49 PM
PeeGreen 914
Im with you JJ lets get some 914's out there... Jul 15 2011, 03:16 PM
jjackson
Hope you make it next year.
Saw progress posts-l... Jul 16 2011, 06:02 AM
J P Stein The toughest part of most any SCCA AX is gettin... Jul 16 2011, 07:52 AM
Randal
The toughest part of most any SCCA AX is gettin... Jul 16 2011, 11:13 AM
J P Stein Story of my AX life. My 4th run was my quickest 90... Jul 16 2011, 12:10 PM
Randal
Story of my AX life. My 4th run was my quickest 9... Jul 16 2011, 03:12 PM
grantsfo National tour events are not expensive to attend. ... Jul 16 2011, 12:23 PM
Randal
National tour events are not expensive to attend.... Jul 16 2011, 03:18 PM
J P Stein It's audio only & breaking up...pretty sta... Jul 16 2011, 03:41 PM
J P Stein OK, day 1 Packwood NT. 914s in 1 , 3......and only... Jul 16 2011, 09:12 PM
J P Stein Brit said he struggled a bit with a mostly dry tra... Jul 17 2011, 08:28 AM
J P Stein I drove up to Packwood anyway. It rained on the fi... Jul 17 2011, 08:28 PM
Joe Ricard Yep, That's why Autocross is such a bitch. ... Jul 18 2011, 07:42 AM
J P Stein A mostly dry track makes things a tad tricky.
htt... Jul 18 2011, 08:52 AM
PeeGreen 914 The second day lay out was much better than the fi... Jul 18 2011, 09:27 AM
Randal Congratulations to Britain on some great runs.
Th... Jul 18 2011, 01:11 PM
Randal
T... Jul 18 2011, 08:25 PM
grantsfo
... Jul 18 2011, 08:54 PM
grantsfo Congrats to Brit. Sounds like he has the beast un... Jul 18 2011, 01:37 PM
PeeGreen 914
Congrats to Brit. Sounds like he has the beast u... Jul 18 2011, 02:41 PM
J P Stein I felt bad for the fist 2 run groups. It was slopp... Jul 18 2011, 03:54 PM
PeeGreen 914
I felt bad for the fist 2 run groups. It was slop... Jul 18 2011, 04:12 PM
jjackson Congrats to Brit,Adam, and Leeds.Fantastic results... Jul 18 2011, 06:02 PM
J P Stein
I felt bad for the fist 2 run groups. It was slo... Jul 28 2011, 12:53 PM
PeeGreen 914
[quote name='PeeGreen 914' post='1511154' date='J... Jul 29 2011, 11:07 AM
J P Stein
Do you have anything else you'd like to say t... Jul 29 2011, 06:13 PM
Randal
I felt bad for the fist 2 run groups. It was slo... Jul 28 2011, 01:52 PM
grantsfo
[quote name='PeeGreen 914' post='1511154' date='J... Aug 4 2011, 02:03 PM
grantsfo Yeah I go to same tire shop that mustang goes to. ... Jul 18 2011, 07:25 PM
Randal The A15 compound is a soft rain compound, but buil... Jul 28 2011, 01:51 PM
Joe Ricard Great big fat slicks. Not the new DOT-R Jul 29 2011, 08:51 AM
PeeGreen 914 Classy as usual <_< Jul 29 2011, 09:43 PM
SirAndy Geeeze, you two sound like my ex-wife(s). :unsure... Jul 29 2011, 11:27 PM
SirAndy Geeeze, you two sound like my ex-wife(s). :unsure... Jul 30 2011, 12:40 AM
PeeGreen 914 :( Damn, sorry to hear that Andy. My mom was just ... Jul 30 2011, 09:24 AM
BMXerror Now that that unpleasantness is behind us...
I hav... Jul 31 2011, 09:27 PM
Joe Ricard I just bought a set of the RS3's in 225/45-17 ... Aug 1 2011, 08:12 AM
grantsfo Hey Brit is signed up for XP! Who hoo! T... Aug 4 2011, 02:13 PM
PeeGreen 914
Hey Brit is signed up for XP! Who hoo! ... Aug 4 2011, 02:38 PM
grantsfo
Good luck Grant. I hope you do well out there,
... Aug 4 2011, 04:02 PM
Randal
... Aug 5 2011, 02:13 PM
jjackson
Hey Brit is signed up for XP! Who hoo! ... Aug 5 2011, 06:35 AM
Randal
[quote name='grantsfo' post='1519482' date='Aug 4... Aug 5 2011, 02:15 PM
jjackson
Nope-Talking about the year that Jeff and Stacy b... Aug 5 2011, 04:32 PM
grantsfo
Nope-Talking about the year that Jeff and Stacy ... Aug 9 2011, 02:43 PM
ottox914
Hey Brit is signed up for XP! Who hoo! ... Aug 5 2011, 08:07 AM
Joe Ricard I've been to several National events haveing n... Aug 5 2011, 09:20 AM
PeeGreen 914 Best of luck Jay. Hope to be out there next year t... Aug 5 2011, 07:39 PM
jjackson
Best of luck Jay. Hope to be out there next year ... Aug 5 2011, 08:20 PM
hot_shoe914
Best of luck Jay. Hope to be out there next year... Aug 6 2011, 11:34 AM
jjackson Those pesky noise meters!!!
Third muff... Aug 6 2011, 02:26 PM
Joe Ricard Someone forgot to tell Sports car mag that Britt a... Aug 6 2011, 06:39 PM
J P Stein
Someone forgot to tell Sports car mag that Britt ... Aug 6 2011, 07:55 PM
BMXerror I'm not sure what everybody else is running, b... Aug 7 2011, 12:37 AM
Randal Best of luck to The Where2Race sponsored 914 yello... Aug 7 2011, 11:01 PM
J P Stein Brit is thrashin' (it's good for him :D )... Aug 8 2011, 07:26 AM
Randal
Brit is thrashin' (it's good for him :D ... Aug 8 2011, 08:55 AM
7275914911 That 911 ran SSM in B'ville this year.....I wa... Aug 9 2011, 01:51 PM
J P Stein That suspension set-up don't look too shinny, ... Aug 8 2011, 10:30 AM
Britain Smith I will never forget that picture! I saw it a ... Aug 8 2011, 04:21 PM
Britain Smith Run/Work order published. Looks like XP runs Heat... Aug 8 2011, 04:24 PM
jjackson Britain-We'll be running third heat also-just ... Aug 8 2011, 05:19 PM
Joe Ricard And for all us poor bastards not going at least w... Aug 9 2011, 10:47 AM
grantsfo I put money on Brit placing 3rd this year if the c... Aug 9 2011, 02:49 PM
Britain Smith
I put money on Brit placing 3rd this year if the ... Aug 9 2011, 05:26 PM
grantsfo
I put money on Brit placing 3rd this year if the... Aug 9 2011, 06:22 PM
PeeGreen 914
[quote name='Britain Smith' post='1522200' date='... Aug 9 2011, 10:23 PM
jjackson Brit,Definitely pulling for you but my money is on... Aug 9 2011, 03:11 PM
BMXerror A little confused at absolutely no mention of Brit... Aug 9 2011, 03:27 PM
jjackson Articles for this issue were written before the cu... Aug 9 2011, 05:01 PM
BMXerror I'd be ecstatic with anything in the trophies ... Aug 9 2011, 07:33 PM
Joe Ricard It's pretty humbling to go to Nationals. I dro... Aug 10 2011, 01:31 PM
grantsfo One thing I hold onto is I beat Toby in BSP in San... Aug 11 2011, 03:46 PM
BMXerror
One thing I hold onto is I beat Toby in BSP in Sa... Aug 11 2011, 10:07 PM
BMXerror To anybody interested, keep an eye out for Jeff St... Aug 13 2011, 10:22 PM
hot_shoe914 Britan, watch out for Richard Holden AND his co-dr... Aug 13 2011, 11:22 PM
J P Stein
Britan, watch out for Richard Holden AND his co-d... Aug 16 2011, 10:09 AM
grantsfo
Britan, watch out for Richard Holden AND his co-... Aug 16 2011, 12:37 PM
Joe Ricard The real question is how many seconds will Beth be... Aug 15 2011, 12:10 PM
grantsfo
The real question is how many seconds will Beth b... Aug 16 2011, 12:30 PM
PeeGreen 914
The real question is how many seconds will Beth ... Aug 16 2011, 01:17 PM
grantsfo JJ I think this is Toby's car post mods. Look... Aug 16 2011, 02:29 PM
jjackson
JJ I think this is Toby's car post mods. Loo... Aug 16 2011, 08:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:01 PM |
