> Cutout still exists....., what to try next, I'm going crazy!!!
porsche735
post Apr 14 2003, 10:52 AM
This is back to the problem in right hand turns and at high rpm. We get a studder until we either turn right to clear it or upshift and hit a lower rpm. We have replaced almost everything. Let me explain what we have done (doesn't mean that a "new" item we have replaced is not bad as well). By the way, the engine has been rebuilt several times over this past 7 years..
Timeline:
Problem started about 7 years ago. Had bucking at freeway speeds.
Took to Reitmeir's and they replaced the FI trigger points- problem went away.
Problem came back again.
We "hardwired" the coil to see if it was iginition- was not
We rebuilt our FI wire harness and installed new TPS- problem went away for a while
Problem came back again. This time also with LEFT hand turns.
Replaced the MPS with a rebuilt one- problem went away for a while
Replaced the relay board- no change
Installed Pertronix ignitor- no change
Moved the fuel pump to front and replaced fuel pump and filter- no change
Replaced the FI brain- problem went away for a while
Problem came back again. Still left hand turns, but also noticed an RPM sensitivity.
Replaced FI trigger points again- problem went away for a while
Replaced the coil and plug wires (but used the same ends)- no change
Rented the FI tester from PP and found a suspect wire in our FI harness- problem went away for a while.
Figured our wires in our harness were brittle so we bought a Bowlsby harness- problem went away for a while.
Installed a MSD- don't get me started here but it ruined 4 pistons individually shearing off the ring lans and causing multiple engine rebuilds- removed MSD.
Replaced the MPS with a new unit- no change
Cleaned up what we think were all the grounds again (firewall by relay board, on the engine for FI, Transmission ground, Battery to chassis ground- that's all, if there are others let me know)- no change
Fuel injectors were flowed- engine felt more balanced at idle, but problem not fixed
Finally we did this-
Connected a long hose to the FI port and attached the pressure gauge so we could see it while running. Used a 2 channel battery powered O-scope and connected to FI#3 and the coil. We ran the car until the problem occurred (just down the street). We saw pressure was steady, coil voltage was steady, FI#3 pulses went to hell- went from nice pulses to noise).
We replaced the FI trigger points and re-ran with same setup- problem not seen
Problem came back.
Latest rebuild of the engine-problem no happens in RIGHT hand turns and with high rpm
Decided it must be the distributor as with shaft wobble that would explain the noisy signal on the FI#3 injector (just the only one we wired up not specifically #3, assume them all) , the rpm sensitivity and the turning sensitivity (but no the movement from LEFT to RIGHT this year)
Guy at distributor rebuild place said our distibutor was shot with lots of wobble and off about 12 degrees at high rpm.
Put in new distributor and it idled better (no hunting) figured we had it licked.
First turn at Butonwillow- the problem was back
We swapped out with a known good other distributor (thinking maybe the rebuild was bad) and the problem was still there (still in RIGHT hand turns and rpm).
Borrowed another MPS from Kevin and Greg- problem was still there.
Put in another coil-problem was still there.
SO, that brings us to today- I don't get it....
Here is our list of items that could be rpm and/or g related and some notes:
FI trigger points- replaced with new distributor, no change- NOT it
Distributor- replaced with new distributor, no change- NOT it
FI brain- replaced once , but still suspect it there a test for high rpm signal integrity?
Rotor cap- replaced, no change
Pertronix- replaced with new distributor with point, no change- NOT it
Spark plug, coil wires- replaced, no change, but could be possible since old connectors used
Relay board- replaced with no change, what really goes bad on these
Are there other ground points we are missing?
Main wiring harness issue- but doesn't explain the rpm related issue
MPS- replaced with working one, no change- NOT it
FI harness issues- we have had connector issue with the Bowlsby harness and had to replace one wire going to Trigger points
Coil- replaced with another one. One thing I noticed is there is .8v at the negative (#1) terminal and 11.4 volts across #1 and #15. Is this normal, or is there a ground we are missing?- however, hardwiring this in the past had no effect... of course we did not hardwire the ground..., but problem on Oscope showed issue at injectors and coil voltage was constant
Fuel pressure- verified with pressure meter during issue, not movement constant 29.5 psi
TPS- problem is not full throttle related, but rpm related and it is basically new
PLEASE HELP ME!!!!
Thanks for all your stabs at this in advance, I will try anything.
Chris Kolstad
1973 914 2.0L BP
porsche735
post Apr 14 2003, 12:50 PM
Standard type battery. Been there for 8 months. Battery voltage looks fine.
Yes, coil voltage seemed low to me as well which is why I pointed it out. Thsi was measured at key-on, not at full load.
As for the key thing, nope, just the ignition key and a light plastic key fob. This is purely a race car, so no house keys.... I did replace teh ignition switch BTW. Forgot to list that...
Back to the alternator, it is old, but it seems to be charging fine...
Like i said in my timeline, I hooked the coil up to the oscope and it did not vary in voltage (up or down) when the problem occurred.
chris
BTW Brad...thanks for the offer, but I'd rathre not "Bare with you"....;-)
porsche735   Cutout still exists.....   Apr 14 2003, 10:52 AM
Jeffs9146   The head temp sensor could have an intermintant fa...   Apr 14 2003, 11:15 AM
porsche735   Thanks. I did replace the head temp sensor during...   Apr 14 2003, 11:35 AM
Brad Roberts   Hows the main harness look to the column/ignition ...   Apr 14 2003, 11:41 AM
porsche735   Main harness looks OK- have checked it out before ...   Apr 14 2003, 11:54 AM
James Adams   Do you have a big heavy key ring hanging off the i...   Apr 14 2003, 11:55 AM
Brad Roberts   Bare with me. I want to think about everything you...   Apr 14 2003, 12:02 PM
porsche735   Standard type battery. Been there for 8 months. ...   Apr 14 2003, 12:50 PM
Jeffs9146   Yes, the sensor only adjusts the fuel/air mixture....   Apr 14 2003, 01:22 PM
SirAndy   try a different engine. put your engine in a diffe...   Apr 14 2003, 01:32 PM
porsche735   Yeah, uh thanks Andy. If you have a donor car, we...   Apr 14 2003, 03:20 PM
Brad Roberts   Alternator at 6Krpm (which is where you would ente...   Apr 14 2003, 03:24 PM
porsche735   Yep, I do still owe you a beer. Maybe two by now ...   Apr 14 2003, 03:31 PM
Brad Roberts   OK. The tube frame race car was having a cutout p...   Apr 14 2003, 04:20 PM
porsche735   So, does anyone have a good used alternator they w...   Apr 14 2003, 04:30 PM
Brad Roberts   I can bring 1-2 of them down with me. The problem ...   Apr 14 2003, 04:42 PM
Aaron Cox   uhh...since your engine is having problems....what...   Apr 14 2003, 04:47 PM
Brad Roberts   They are building a 911. No need for a conversion....   Apr 14 2003, 04:51 PM
Mueller   Chris.....you want an alt? Email me tommorow in t...   Apr 14 2003, 04:54 PM
porsche735   Yep, same alternator. All we do is unplug the cab...   Apr 14 2003, 04:54 PM
Aaron Cox   :huh: ? am i missing somethin? I thought they wer...   Apr 14 2003, 04:56 PM
porsche735   Mike, I'll check out the car with the alt unpl...   Apr 14 2003, 04:57 PM
porsche735   Yep, we have an '89 Carrera Cabrio we will be ...   Apr 14 2003, 05:02 PM
Aaron Cox
- Lo-Fi Version Time is now: 6th July 2025 - 10:06 AM
