914-6 Gen light comes on when hooking up the battery. |
Porscheman912 |
Aug 17 2011, 08:00 PM
Newbie Group: Members Posts: 20 Joined: 21-June 09 From: Washington Member No.: 10,492 Region Association: None |
Ok, I have a friends 914-6 here, and just built the engine in it. Before doing the engine, and after, the Gen light comes on when the car is off. I took the starter, and Alt to a shop to have checked out, and they were both good. Replace the Volt reg with another new one I had, and still on. I have a wiring diagram, but does not show wire colors, or switches. The light would go out in 2nd position on the ignition switch, and then come back on. I dropped the fuse panel down, and now it is on in all positions. It goes out when started. I was getting a very light arc when I hooked the battery up, but when I unplug the alt plug from relay board it goes out. I am thinking it may be the ignition switch itself, and just wondering if anyone has seen this on these cars? It is an OEM 6, not a conversion. Any help would be great, I need to get the owner his car back, and I am still testing things, just trying to save time if someone else has seen this.
914Mels |
Aug 18 2011, 03:19 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
You may have a bad diode in the alternator. It's been years since I had a problem like this. If I remember correctly the car charged normal but the current backflowed through the diode and made the light come on. With the alternator unplugged, the light goes off, right?
Ericv1 |
Aug 18 2011, 04:31 PM
Member Group: Members Posts: 259 Joined: 30-December 07 From: Cincinnati, Ohio Member No.: 8,518 Region Association: Upper MidWest |
You may have a bad diode in the alternator. It's been years since I had a problem like this. If I remember correctly the car charged normal but the current backflowed through the diode and made the light come on. With the alternator unplugged, the light goes off, right? I agree. I had to replace my alternator earlier this year because of the same issue. |
Lo-Fi Version | Time is now: 29th May 2024 - 02:48 AM |
