74 2.0 LE Trouble- Backfiring & no power, New used MPS helped! Still some fine tuning needed |
JRust |
Jul 28 2011, 01:41 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay so I flat towed the LE down to Monterey CA 2 weeks ago. Car ran great while there. When I got home it was backfiring & running like crap. It has no power & won't stay running. The only strange thing was when I hooked it back up to bring it home. I got it all hooked up & forgot it was in gear (reverse). I put my Excursion in drive & had resistence. I didn't move more than 5 ft before I stopped. I went back & took it out of gear. I also had the ebrake on which I put down too. Started the car real quick & no problems. Turned it off & headed home. When I got unhooked at home it ran like crap (IMG:style_emoticons/default/WTF.gif)
So far I just checked all my hoses to be sure everything was on. I checked all my spark plug wires & they were as should be. I popped my distributor cap & saw nothing obviously wrong. Car doesn't want to stay running so I haven't pulled any spark plugs wires to see if it makes a difference. Just looking for some suggestions of things to check. It does have gas (IMG:style_emoticons/default/blink.gif) |
Bartlett 914 |
Aug 19 2011, 04:39 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Make sure your valves are adjusted. I think you may still be lean
JRust |
Aug 20 2011, 10:26 AM
Make sure your valves are adjusted. I think you may still be lean I will check my valves. I know my tranny was leaking but looks like I have an oil leak somewhere too. I will be looking into that more today. I am pulling the tranny this morning. I've got to get my heating tubes all together too. One of the things that disapeared when it sat at the shop not getting worked on for a year (IMG:style_emoticons/default/dry.gif) . So I need to see if I can put together what I need from my spare parts (IMG:style_emoticons/default/sad.gif) . Something about having the day to work on my 914 just puts a (IMG:style_emoticons/default/biggrin.gif) on my face. Not quite as big as when I get to actually drive them. Still a good day though |
Lo-Fi Version | Time is now: 10th June 2024 - 02:01 AM |
