| VaccaRabite |
Aug 19 2011, 07:34 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,929 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
New problem. (yay!)
For whatever reason, as soon as I turn the key, before the engine starts, the VDO oil pressure gauge pegs out well past 80psi (probably 120, but 80 is the higest number.) The idiot light works as expected. Its green while the engine is cranking, but goes out about 1 second after the engine fires. The sender is the standard VDO dual sender using a paintball hose remote hose, and a study mount to the case. I have switched the leads at the sender to rule that out. I cleaned the ground between the sender and the mount. Not yet cleaned where the mount attaches to the engine case, but the connection there is solid and has lots of contact. I forget how the sender works. Does it work by grounding itself? Possible causes: Bad sender. Bad gauge. wire pinched somewhere between the gauge and the sender? wire pinched between fuse block and gauge? Missing something? Spend too much time trouble shooting this, and the car is still idling too high. No more time to work tonight. Sick. (IMG:style_emoticons/default/sad.gif) Zach |
| '73-914kid |
Aug 20 2011, 10:46 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
On cold mornings, my gauge would occasionally peg with cold oil, due to the sheer pressure. One morning, the gauge was running at 60psi at idle, and then I went off to drive, gauge pegged as it sometimes would, then when I pulled up to a stop sign, the gauge stayed pegged.. took the sender out, and it turned out I broke the sender. It was a very old sender, but it still broke due to being overpressurized I believe.
Vacca Rabite VDO oil presure gauge pegged Aug 19 2011, 07:34 PM
underthetire Just ground the lead and see if it changes. If I r... Aug 19 2011, 07:52 PM
JimN73 Oil pressure is highest when the engine is cold. ... Aug 19 2011, 08:59 PM
JimN73 Oil pressure is highest when the engine is cold. ... Aug 19 2011, 09:02 PM
Vacca Rabite Usually the engine needs to be turning to make pre... Aug 19 2011, 11:15 PM
Valy Might be the zener diode inside the gauge is kaput... Aug 19 2011, 11:34 PM
Dave_Darling Wires hooked up to the gauge correctly? Ground, p... Aug 20 2011, 12:42 AM
ArtechnikA generally, for a VDO electric guage, open signal w... Aug 20 2011, 06:28 AM
Vacca Rabite Wonderful. That will be helpful. Tonight I'll ... Aug 20 2011, 06:51 AM
ArtechnikA
Reading full on eliminates bad connections betwee... Aug 20 2011, 07:47 AM
StratPlayer Having the same problem,,, Aug 20 2011, 09:28 AM
tradisrad The sender must be grounded or it will peg the gag... Aug 20 2011, 10:32 AM
Elliot Cannon I had the same problem. Turned out to be a bad se... Aug 20 2011, 01:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd November 2026 - 07:39 AM |
