| bradtho |
Aug 22 2011, 11:18 PM
Member ![]() ![]() Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
I'm thinking about taking my stock 1.7 to a 1911. Some old threads seem to suggest that you can't do this with the 1.7l heads, while others seem to suggest it's fine. Can anybody set me straight on if I would need new heads, if they'd need to be machined, or if I'm good to go?
Also, I've got 2 engines all with original german cylinders. Am I better off taking the best 4 and boring them out or going with new chinese cylinders (local shop recommends QSC). I've been thinking if I've got 4 decent ones that the OE cylinders would likely be better than the chinese stuff. anything else I should be thinking about? |
| TargaToy |
Aug 23 2011, 07:46 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- ![]() ![]() ![]() Group: Members Posts: 714 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region
Yes, Jake. Can you please post the 1911 stats before the site goes down for 4 days??? (IMG:style_emoticons/default/biggrin.gif)
bradtho building a 1911 from a 1.7 Aug 22 2011, 11:18 PM
Jake Raby Yes you can do this with the existing heads if you... Aug 23 2011, 12:10 AM
Valy
Jake,
Nice write-out but you better fix the ... Aug 23 2011, 03:02 PM
Vacca Rabite My 2056 uses 1.7 heads. It can be done.
That said... Aug 23 2011, 07:01 AM
HAM Inc What sort of performance are expecting from your 1... Aug 23 2011, 07:48 AM
bradtho
What sort of performance are expecting from your ... Aug 23 2011, 08:58 AM
69telecaster 35 years ago I bought a set of 96mm cylinders/pist... Aug 23 2011, 08:39 AM
HAM Inc 1.7's will work fine, but you'll need to h... Aug 23 2011, 10:49 AM
Jake Raby I didn't post it to sell stuff :-)
The majorit... Aug 23 2011, 03:20 PM
jmill Jake, I seem to recall you posting a dyno sheet an... Aug 23 2011, 04:41 PM
TargaToy :bump: Aug 26 2011, 05:59 PM
jmill Found it. http://www.914world.com/bbs2/index.php?... Aug 26 2011, 06:31 PM
7275914911
Found it. [url=http://www.914world.com/bbs2/inde... Aug 27 2011, 10:00 AM
pete-stevers Funny thing i was thinking along the same lines...... Aug 26 2011, 07:54 PM
pete-stevers I would love to see how much juice could be made f... Aug 26 2011, 07:55 PM
HAM Inc How about a 90.5 x 78.4=2017cc's. Use the 1.7 ... Aug 27 2011, 09:41 AM
r_towle
How about a 90.5 x 78.4=2017cc's. Use the 1.7... Aug 27 2011, 01:50 PM
TargaToy THANK YOU for finding and posting the link. This ... Aug 27 2011, 12:36 PM
jmill
Try this one....
1911 Recipe
That's it... Aug 27 2011, 02:18 PM
LukeD
[quote name='7275914911' post='1530648' date='Aug... Jun 25 2015, 10:23 PM
HAM Inc
The nice thing about the long stroke-small bore ... Aug 27 2011, 02:29 PM
pete-stevers What type of carbs did you run in that set up? Aug 27 2011, 03:22 PM
bam914 My dad has a 1911 in his 914. Len did the heads. ... Aug 27 2011, 03:27 PM
ripper911
My dad has a 1911 in his 914. Len did the heads.... Aug 28 2011, 05:38 PM
HAM Inc
I don't remember what it ended up with. Once... Aug 27 2011, 09:09 PM
bradtho OK, so Ham says no-go on boring my OE 1.7 cylinder... Aug 27 2011, 11:40 PM
HAM Inc I'm not going to comment on the Chinese cylind... Aug 28 2011, 07:59 AM
lonewolfe
I'm not going to comment on the Chinese cylin... Aug 3 2015, 01:50 AM
914_teener
I'm not going to comment on the Chinese cyli... Aug 3 2015, 09:48 AM
Dave_Darling There were 96es that fit 1.7 heads. They were ver... Aug 28 2011, 06:21 PM
rhodyguy interesting what you can find with a tablet. jake... Jun 25 2015, 06:12 PM
Dave_Darling It'll require some tweaking of the MPS, and po... Jun 26 2015, 08:49 AM
MikeInMunich
It'll require some tweaking of the MPS, and p... Apr 12 2020, 12:34 AM
lonewolfe Who makes and sells the 90.5 stroker pistons? Aug 3 2015, 10:35 AM
rhodyguy read jakes take on the 1.8 heads. in most cases th... Aug 3 2015, 10:37 AM
914werke Resurrection:
No one appeared to answer the questi... Nov 2 2017, 02:18 PM
Dave_Darling Check with AA Pistons. The 90.5 were a stock repl... Nov 2 2017, 05:28 PM
914_teener Wow....it is hard to believe that was two years ag... Nov 2 2017, 07:09 PM
Montreal914 About 30 years ago :rolleyes: I had a 1776cc type... Nov 2 2017, 08:14 PM
914werke
About 30 years ago :rolleyes: I had a 1776cc typ... Nov 2 2017, 08:51 PM
Montreal914
About 30 years ago :rolleyes: I had a 1776cc ty... Nov 2 2017, 09:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 05:46 PM |
