> building a 1911 from a 1.7, will my existing heads work?
bradtho
post Aug 22 2011, 11:18 PM
I'm thinking about taking my stock 1.7 to a 1911. Some old threads seem to suggest that you can't do this with the 1.7l heads, while others seem to suggest it's fine. Can anybody set me straight on if I would need new heads, if they'd need to be machined, or if I'm good to go?
Also, I've got 2 engines all with original german cylinders. Am I better off taking the best 4 and boring them out or going with new chinese cylinders (local shop recommends QSC). I've been thinking if I've got 4 decent ones that the OE cylinders would likely be better than the chinese stuff.
anything else I should be thinking about?
HAM Inc
post Aug 27 2011, 09:41 AM
How about a 90.5 x 78.4=2017cc's. Use the 1.7 heads and have a seriously torquey low rev beast. That would get good mileage and be fun to drive!
r_towle
post Aug 27 2011, 01:50 PM
Custom Member
QUOTE(HAM Inc @ Aug 27 2011, 11:41 AM) *
have you ever tried this with 2.0 liter heads?
Some sort of cylinder ring might do the trick...
Wondering if this setup, with the higher flowing heads, may get to that magic 40mpg number....
I recall Jake got into the 30's but never got to 40mpg.
The stock 1.7 can get into the 30's.....
Rich
bradtho   building a 1911 from a 1.7   Aug 22 2011, 11:18 PM
Jake Raby   Yes you can do this with the existing heads if you...   Aug 23 2011, 12:10 AM
Valy   ... Jake, Nice write-out but you better fix the ...   Aug 23 2011, 03:02 PM
Vacca Rabite   My 2056 uses 1.7 heads. It can be done. That said...   Aug 23 2011, 07:01 AM
HAM Inc   What sort of performance are expecting from your 1...   Aug 23 2011, 07:48 AM
bradtho   What sort of performance are expecting from your ...   Aug 23 2011, 08:58 AM
69telecaster   35 years ago I bought a set of 96mm cylinders/pist...   Aug 23 2011, 08:39 AM
HAM Inc   1.7's will work fine, but you'll need to h...   Aug 23 2011, 10:49 AM
Jake Raby   I didn't post it to sell stuff :-) The majorit...   Aug 23 2011, 03:20 PM
jmill   Jake, I seem to recall you posting a dyno sheet an...   Aug 23 2011, 04:41 PM
TargaToy   Yes, Jake. Can you please post the 1911 stats bef...   Aug 23 2011, 07:46 PM
TargaToy   :bump:   Aug 26 2011, 05:59 PM
jmill   Found it. http://www.914world.com/bbs2/index.php?...   Aug 26 2011, 06:31 PM
7275914911   Found it. [url=http://www.914world.com/bbs2/inde...   Aug 27 2011, 10:00 AM
pete-stevers   Funny thing i was thinking along the same lines......   Aug 26 2011, 07:54 PM
pete-stevers   I would love to see how much juice could be made f...   Aug 26 2011, 07:55 PM
HAM Inc   How about a 90.5 x 78.4=2017cc's. Use the 1.7 ...   Aug 27 2011, 09:41 AM
r_towle   How about a 90.5 x 78.4=2017cc's. Use the 1.7...   Aug 27 2011, 01:50 PM
TargaToy   THANK YOU for finding and posting the link. This ...   Aug 27 2011, 12:36 PM
jmill   Try this one.... 1911 Recipe That's it...   Aug 27 2011, 02:18 PM
LukeD   [quote name='7275914911' post='1530648' date='Aug...   Jun 25 2015, 10:23 PM
HAM Inc   The nice thing about the long stroke-small bore ...   Aug 27 2011, 02:29 PM
pete-stevers   What type of carbs did you run in that set up?   Aug 27 2011, 03:22 PM
bam914   My dad has a 1911 in his 914. Len did the heads. ...   Aug 27 2011, 03:27 PM
ripper911   My dad has a 1911 in his 914. Len did the heads....   Aug 28 2011, 05:38 PM
HAM Inc   I don't remember what it ended up with. Once...   Aug 27 2011, 09:09 PM
bradtho   OK, so Ham says no-go on boring my OE 1.7 cylinder...   Aug 27 2011, 11:40 PM
HAM Inc   I'm not going to comment on the Chinese cylind...   Aug 28 2011, 07:59 AM
lonewolfe   I'm not going to comment on the Chinese cylin...   Aug 3 2015, 01:50 AM
914_teener   I'm not going to comment on the Chinese cyli...   Aug 3 2015, 09:48 AM
Dave_Darling   There were 96es that fit 1.7 heads. They were ver...   Aug 28 2011, 06:21 PM
rhodyguy   interesting what you can find with a tablet. jake...   Jun 25 2015, 06:12 PM
Dave_Darling   It'll require some tweaking of the MPS, and po...   Jun 26 2015, 08:49 AM
MikeInMunich   It'll require some tweaking of the MPS, and p...   Apr 12 2020, 12:34 AM
lonewolfe   Who makes and sells the 90.5 stroker pistons?   Aug 3 2015, 10:35 AM
rhodyguy   read jakes take on the 1.8 heads. in most cases th...   Aug 3 2015, 10:37 AM
914werke   Resurrection: No one appeared to answer the questi...   Nov 2 2017, 02:18 PM
Dave_Darling   Check with AA Pistons. The 90.5 were a stock repl...   Nov 2 2017, 05:28 PM
914_teener   Wow....it is hard to believe that was two years ag...   Nov 2 2017, 07:09 PM
Montreal914   About 30 years ago :rolleyes: I had a 1776cc type...   Nov 2 2017, 08:14 PM
914werke   About 30 years ago :rolleyes: I had a 1776cc typ...   Nov 2 2017, 08:51 PM
Montreal914   About 30 years ago :rolleyes: I had a 1776cc ty...   Nov 2 2017, 09:16 PM
- Lo-Fi Version Time is now: 24th November 2026 - 05:46 PM
