Finally driving again!, Type IV CIS conversion |
dlee6204 |
Jul 17 2011, 09:39 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I finally got to drive my 914 again! (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/biggrin.gif) Back in June I was having fits with the L-Jet system that was on my car so I decided it was time to tackle a project I was wanting to do for some time, a CIS conversion.
I retrofitted a CIS Basic system to my stock 1.8L engine using parts from various VWs and Mercedes and today I fired it up for the first time and was able to take it for a long drive. It felt AWESOME. Smooth reliable power all the way to redline. It has a nice growl to it too. (IMG:style_emoticons/default/evilgrin.gif) I'm quite impressed. I still have to make some small adjustments but at least now I can get back to driving the car daily and the best part, NO MORE JACKSTANDS! I'm going to drive the snot out of the car this week to get the system dialed in and hopefully next weekend I will take it for a day drive in the mountains. (IMG:style_emoticons/default/driving.gif) More details and pics to come later. The cat is happy too! |
Prospectfarms |
Jul 22 2011, 09:16 PM
Member Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
I've followed this thread hoping to find relief from the oppression of the MAPS, a part that is, in my limited experience, too fragile, too hard to find, and too critical to operation of the d-jet system for my comfort. Under that criteria, and given the fact that I don't have a super-sized motor to fuel, I don't think of k-jet as a viable alternative to my imperfectly stock FI. The OP, jcl914, and Rex-n-effect are obviously talented mechanics and/or have identified a supply of spare parts. They put their talents and resources to good and productive use. I'm very grateful they shared their interesting information about CIS but... I've been checking pull-a-part inventories for three cities for the past two weeks for a 1977-79, Rabbit, Dasher, Jetta, or Scirocco and have only found one (later models had the lambda circuit and an ECU). Assuming I found a donor with its fuel system intact, after the conversion I'd be in the same position as I am now with d-jet. No, the critical k-jet components are not obsolete, just insanely expensive (mass airflow sensor/fuel distributor = $1800 at Rockauto). I didn't check the e-bay but with that new price as a point of departure, used k-jet parts are probably just as pricey as d-jet parts. At (new) $200 for an accumulator $75 for an idle air regulator, $200 for a high pressure pump, and $50 for Bosch injectors, repair costs could be prohibitive. I don't know where a stash of late 70's VW' donor's are anymore than I know where a supply of early 70's 914's are. so tracking down a solid ECU MPS, TPS, CHT, and dizzy fuel points for my stock motor doesn't feel different that tracking down a fuel accumulator, mass air flow sensor and fuel distributor, idle air valve, and special injectors. Maybe easier since the stock components have fewer moving parts? Now if you went the next step and converted to K-L - jet ('81 Scirocco's were really neat cars, BTW) with an O2sensor and a lambda control circuit, that might be a different and even more interesting story... |
rohar |
Sep 2 2011, 10:30 PM
Senior Member Group: Members Posts: 924 Joined: 25-October 08 From: spokane Member No.: 9,685 Region Association: None |
... I don't know where a stash of late 70's VW' donor's are anymore than I know where a supply of early 70's 914's are. so tracking down a solid ECU MPS, TPS, CHT, and dizzy fuel points for my stock motor doesn't feel different that tracking down a fuel accumulator, mass air flow sensor and fuel distributor, idle air valve, and special injectors. Maybe easier since the stock components have fewer moving parts? Now if you went the next step and converted to K-L - jet ('81 Scirocco's were really neat cars, BTW) with an O2sensor and a lambda control circuit, that might be a different and even more interesting story... I've not had the problem tracking down used CIS parts in the NW like you're seeing. I can drive about 2 miles and score a whole system. By phone, you might want to give Campbell Nelson a call in Edmonds, Spaldings or Whitey's Wrecking in Spokane. There's probably more, but those three have been good for me over the years. BTW, I was buying K-Jet dizzys for $150 new 10 years ago. Given what they're selling for today, I shoulda bought more off them (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:56 AM |
