Is my Audi A4 head cracked? What to do?, Last update. 10/13. Spewing coolant. |
jk76.914 |
Sep 5 2011, 07:27 AM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
I may be in a pickle. My daughter's 2004 Audi A4 1.8T, 105,000 miles, was using some coolant. I looked and looked and looked, there was no evidence of a leak. It used about a pint every 500-1000 miles, so I thought there should be some visible sign, but no. There's no symptom at all. Nothing wet, driveway dry, no smoke, starts good, runs fine....
But then yesterday, after topping it off again, I changed the plugs. The threads on the #4 plug were wet. The other three not. I'm guessing a crack from the plug to the water jacket somehow, and it probably opens up at temperature, seeping coolant into the combustion chamber. What do you guy's think? The wet threads seem to confirm the diagnosis... Any other ideas? Anybody know if these things are prone to cracking? Any danger in trying a Bars Leaks sealant? They're pretty well regarded, I think, and they have four products for cracks, head gaskets, etc... I'm thinking of trying the mildest first. She commutes from Boston to Rhode Island daily, putting about 400 miles on the car every week. Here's a picture of the 5 valve combustion chamber I found on line. Lots of opportunities here for cracks... Help! |
Mike Bellis |
Sep 5 2011, 07:39 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Might be a cracked head. Might be a head gasket. Either way you will need to fix it. The stop leak may work for a while. Or not at all. You could try it. Most of these typs of leak seal need a hot engine to work. Make sure you follow the directions exactly. Remember, these types of products all plug up radiators also while fixing a leak. Any pinch point in the cooling system will attract the stop leak.
Lo-Fi Version | Time is now: 5th June 2024 - 10:52 AM |
