Is my Audi A4 head cracked? What to do?, Last update. 10/13. Spewing coolant. |
jk76.914 |
Sep 5 2011, 07:27 AM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
I may be in a pickle. My daughter's 2004 Audi A4 1.8T, 105,000 miles, was using some coolant. I looked and looked and looked, there was no evidence of a leak. It used about a pint every 500-1000 miles, so I thought there should be some visible sign, but no. There's no symptom at all. Nothing wet, driveway dry, no smoke, starts good, runs fine....
But then yesterday, after topping it off again, I changed the plugs. The threads on the #4 plug were wet. The other three not. I'm guessing a crack from the plug to the water jacket somehow, and it probably opens up at temperature, seeping coolant into the combustion chamber. What do you guy's think? The wet threads seem to confirm the diagnosis... Any other ideas? Anybody know if these things are prone to cracking? Any danger in trying a Bars Leaks sealant? They're pretty well regarded, I think, and they have four products for cracks, head gaskets, etc... I'm thinking of trying the mildest first. She commutes from Boston to Rhode Island daily, putting about 400 miles on the car every week. Here's a picture of the 5 valve combustion chamber I found on line. Lots of opportunities here for cracks... Help! |
HAM Inc |
Sep 5 2011, 12:43 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
QUOTE I guess BMW 6 cylinder heads are left out of this thought...they all leak once cracked, but only at hot temps... Rich I've repaired many-a M20, M50,-M54 BMW head over the years. They do leak when not running, just notmuch. The cracks typically won't pass enough fluid when the engine isn't running to be noticed. But let the car sit for a long time and the coolant will slowly drain through the crack. Seen it plenty of times. |
Lo-Fi Version | Time is now: 5th June 2024 - 07:42 AM |
