Electrical Gurus - looking for information on pin#13 |
Scott S |
Sep 7 2011, 10:12 AM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi There -
Per the chart below, is pin #13 on the engine comaprtment 14 pin plug a true keyed power source? Being that the chart does not list the fuse it goes to (like it does on pin #8) I am a bit confused. I need to create a harness for my fuel pump and need a keyed power source for the relay. The PO of my car installed a faucet pump and ran it off of the positive side of the coil. I need to check again, but I am pretty confident that the original wires were removed, and for now, I want the new pump (carter 4070) to reside in the stock (rear) location. Thanks Very Much - (IMG:style_emoticons/default/beerchug.gif) Scott S Attached image(s) |
Scott S |
Sep 7 2011, 03:06 PM
I thnk I am beginning to understand why the PO just ran a wire to the coil! ha!
(IMG:style_emoticons/default/beerchug.gif) |
swl |
Sep 7 2011, 04:02 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
I thnk I am beginning to understand why the PO just ran a wire to the coil! ha! (IMG:style_emoticons/default/beerchug.gif) he and just about everyone else that has done a carb conversion. It is a fun exercise though for a mad scientist. If it works then you can pick up your fuel pump power from the original wiring harness. |
Lo-Fi Version | Time is now: 6th June 2024 - 04:30 AM |
