| bradtho |
Sep 11 2011, 05:49 PM
Member ![]() ![]() Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
I've read several threads on case splitting and been over the classic "splitting case halves" pictures at least 3 times. I'm pulling on the tranny studs, and not seeing any gap form at all. here's some pictures in case someone is able to spot a bolt that I've missed. I'm avoiding the use of screwdrivers, but what would your next steps be assuming that I haven't in fact missed a bolt.
the big 6 ![]() along the top ![]() down the front (you think the front main seal was leaking?) ![]() the sneaky 2 on the side ![]() the one behind the flywheel ![]() sneaky one below the flywheel and back half of bottom ![]() front half of bottom ![]() |
| McMark |
Sep 11 2011, 06:47 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
You can safely apply pressure by wedging a screwdriver between the crank and the front main seal. That way you have the hardened crank on one side and the rubber seal on the other and you can usually get it started there.
It looks like you got all the nuts and bolts. But if it doesn't crack open with light pressure there, don't just push harder. Sometimes the sealant used on the case halves can make splitting a PITA. |
bradtho yet another case won't split thread Sep 11 2011, 05:49 PM
tomeric914 If you forceably tried to pull the 6 thru case stu... Sep 11 2011, 06:16 PM
bradtho
If you forceably tried to pull the 6 thru case st... Sep 11 2011, 08:39 PM
McMark
You can safely apply pressure by wedging a screwd... Sep 17 2011, 08:02 PM
bradtho
You can safely apply pressure by wedging a screw... Sep 17 2011, 08:04 PM
stugray I use my woodworkers plastic clamps.
You can rever... Sep 11 2011, 07:21 PM
Valy
Hard to say but, in this picture there is one ... Sep 12 2011, 08:20 AM
bradtho
Hard to say but, in this picture there is one ju... Sep 12 2011, 08:44 AM
bradtho weekend again, so I'm back at it. i tapped the... Sep 17 2011, 03:42 PM
McMark I think she's talking about this one... Sep 12 2011, 09:40 AM
Valy
:ag... Sep 12 2011, 11:11 AM
McMark
:a... Sep 12 2011, 02:46 PM
gothspeed As was mentioned it should not have to be forced t... Sep 12 2011, 10:47 AM
r_towle A block of wood resting on a case tab and a good t... Sep 12 2011, 11:18 AM
Cap'n Krusty With one half of the case securely attached to the... Sep 12 2011, 12:14 PM
McMark Pry between the hub and the seal. ;) Sep 17 2011, 08:07 PM
bradtho
SUCCESS... Sep 17 2011, 08:56 PM
dlee6204 Good work! :trophy: Sep 17 2011, 09:03 PM
McMark Nice job! Some of them are more 'stuck... Sep 18 2011, 09:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:43 PM |
