> yet another case won't split thread, success, finally.
bradtho
post Sep 11 2011, 05:49 PM
I've read several threads on case splitting and been over the classic "splitting case halves" pictures at least 3 times. I'm pulling on the tranny studs, and not seeing any gap form at all. here's some pictures in case someone is able to spot a bolt that I've missed. I'm avoiding the use of screwdrivers, but what would your next steps be assuming that I haven't in fact missed a bolt.
the big 6
along the top
down the front (you think the front main seal was leaking?)
the sneaky 2 on the side
the one behind the flywheel
sneaky one below the flywheel and back half of bottom
front half of bottom
Valy
post Sep 12 2011, 08:20 AM
QUOTE(bradtho @ Sep 11 2011, 04:49 PM) *
Hard to say but, in this picture there is one just above the pulley on the right that seems to still be there.
I also used a woodworkers plastic clamp like Stugray mentioned (and broke one). But, I used it on the oil pump bolts as I was afraid to scratch the oil pump location. Also used it on the flywheel side between 2 bolts.
Also used the hammer handle in the oil breather rectangle.
bradtho
post Sep 12 2011, 08:44 AM
QUOTE(Valy @ Sep 12 2011, 07:20 AM) *
the thermstat pulley? I'm not sure where you're referring to. here's a higher res in case it helps.
bradtho   yet another case won't split thread   Sep 11 2011, 05:49 PM
tomeric914   If you forceably tried to pull the 6 thru case stu...   Sep 11 2011, 06:16 PM
bradtho   If you forceably tried to pull the 6 thru case st...   Sep 11 2011, 08:39 PM
McMark   You can safely apply pressure by wedging a screwdr...   Sep 11 2011, 06:47 PM
McMark   You can safely apply pressure by wedging a screwd...   Sep 17 2011, 08:02 PM
bradtho   You can safely apply pressure by wedging a screw...   Sep 17 2011, 08:04 PM
stugray   I use my woodworkers plastic clamps. You can rever...   Sep 11 2011, 07:21 PM
Valy   Hard to say but, in this picture there is one ...   Sep 12 2011, 08:20 AM
bradtho   Hard to say but, in this picture there is one ju...   Sep 12 2011, 08:44 AM
bradtho   weekend again, so I'm back at it. i tapped the...   Sep 17 2011, 03:42 PM
McMark   I think she's talking about this one...   Sep 12 2011, 09:40 AM
Valy   I think she's talking about this one... :ag...   Sep 12 2011, 11:11 AM
McMark   I think she's talking about this one... :a...   Sep 12 2011, 02:46 PM
gothspeed   As was mentioned it should not have to be forced t...   Sep 12 2011, 10:47 AM
r_towle   A block of wood resting on a case tab and a good t...   Sep 12 2011, 11:18 AM
Cap'n Krusty   With one half of the case securely attached to the...   Sep 12 2011, 12:14 PM
McMark   Pry between the hub and the seal. ;)   Sep 17 2011, 08:07 PM
bradtho   Pry between the hub and the seal. ;) SUCCESS...   Sep 17 2011, 08:56 PM
dlee6204   Good work! :trophy:   Sep 17 2011, 09:03 PM
McMark   Nice job! Some of them are more 'stuck...   Sep 18 2011, 09:27 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:17 PM
