| phillstek |
Sep 12 2011, 01:45 AM
Member ![]() ![]() Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
New Wevo'd 915 from the boys in Phoenix and Tangerine Racing Evo 6 exhaust system all bolted up.
Fired up the engine today after not being run for 12 years! Got oil pressure after a couple of cranks and then she sputtered into life. Webers were dismantled, cleaned and new gasket set fitted beforehand they still need tuning though. Couple of questions re: transmission. What is the recommended oil to use with the 915? Diff is a Wave Trac torque biasing unit. The clearance between the rear shift linkage rod and the headers appears to be very close. Although I haven't bolted it in yet, I fear the rod may contact the exhaust when attempting to shift. Anyone else running this set-up? Thanks again and all comments welcome. Phil Attached image(s)
| Richard Casto |
Sep 12 2011, 09:00 AM
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
Couple of questions re: transmission. What is the recommended oil to use with the 915? Diff is a Wave Trac torque biasing unit. Phil, That all looks very nice! Regarding the transmission lubrication. Internally the 915 is not that different than a 901 (same type of synchros, etc.) It is the post 915 transmissions that have the Borg Warner style synchro that might need a different oil as is used in a 901/915. I would ask your transmission builder for their opinion and with respect to the TB Diff, I am assuming the manufacture would also provide lubrication recommendations. As this is a TB and not a clutch type, I am thinking that you should be able to use regular GL-5 WITHOUT needing something that has LSD specific friction modifiers. I have typed up this document awhile back and it might help... http://www.blueskymotorsports.com/index.ph...16&Itemid=6 Richard |
phillstek Wevo'd and Evo'd Sep 12 2011, 01:45 AM
DEC Interesting header pipe guide/direction
What are ... Sep 12 2011, 02:10 AM
phillstek
What are... Sep 12 2011, 02:18 AM
Racer Chris
What ar... Sep 12 2011, 06:44 AM
Bullethead Nice. That's some header porn! Who makes t... Sep 12 2011, 04:18 AM
edwin Looking real good there Phil.
Might have to drive ... Sep 12 2011, 06:09 AM
phillstek Thanks for the comments.
Headers are Tangerine R... Sep 12 2011, 01:33 PM
Britain Smith As per Hayden at WEVO, you should be using Swepco.... Sep 12 2011, 02:19 PM
phillstek
As per Hayden at WEVO, you should be using Swepco... Sep 12 2011, 06:02 PM
Racer Chris I put the 4cyl car with a WEVO (that I mentioned i... Sep 12 2011, 07:33 PM
phillstek
I put the 4cyl car with a WEVO (that I mentioned ... Oct 31 2011, 04:12 PM
SirAndy :thumbsup: Oct 31 2011, 05:18 PM
JmuRiz Sweet setup, looks great! Oct 31 2011, 08:01 PM
PanelBilly That looks too good! Nov 1 2011, 09:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 18th April 2026 - 05:33 AM |
