| phillstek |
Sep 12 2011, 01:45 AM
Member ![]() ![]() Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
New Wevo'd 915 from the boys in Phoenix and Tangerine Racing Evo 6 exhaust system all bolted up.
Fired up the engine today after not being run for 12 years! Got oil pressure after a couple of cranks and then she sputtered into life. Webers were dismantled, cleaned and new gasket set fitted beforehand they still need tuning though. Couple of questions re: transmission. What is the recommended oil to use with the 915? Diff is a Wave Trac torque biasing unit. The clearance between the rear shift linkage rod and the headers appears to be very close. Although I haven't bolted it in yet, I fear the rod may contact the exhaust when attempting to shift. Anyone else running this set-up? Thanks again and all comments welcome. Phil Attached image(s)
| ChrisFoley |
Sep 12 2011, 07:33 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
I put the 4cyl car with a WEVO (that I mentioned in an email) up on the lift this afternoon.
As far as I can tell, at the tranny connection, the WEVO shift rod is a couple inches higher than the stock sideshift. It isn't any farther to the left though, so there really should be no interference when both ends are connected. |
phillstek Wevo'd and Evo'd Sep 12 2011, 01:45 AM
DEC Interesting header pipe guide/direction
What are ... Sep 12 2011, 02:10 AM
phillstek
What are... Sep 12 2011, 02:18 AM
Racer Chris
What ar... Sep 12 2011, 06:44 AM
Bullethead Nice. That's some header porn! Who makes t... Sep 12 2011, 04:18 AM
edwin Looking real good there Phil.
Might have to drive ... Sep 12 2011, 06:09 AM
Richard Casto
Couple of questions re: transmission. What is the... Sep 12 2011, 09:00 AM
phillstek Thanks for the comments.
Headers are Tangerine R... Sep 12 2011, 01:33 PM
Britain Smith As per Hayden at WEVO, you should be using Swepco.... Sep 12 2011, 02:19 PM
phillstek
As per Hayden at WEVO, you should be using Swepco... Sep 12 2011, 06:02 PM
phillstek
I put the 4cyl car with a WEVO (that I mentioned ... Oct 31 2011, 04:12 PM
SirAndy :thumbsup: Oct 31 2011, 05:18 PM
JmuRiz Sweet setup, looks great! Oct 31 2011, 08:01 PM
PanelBilly That looks too good! Nov 1 2011, 09:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 18th April 2026 - 07:17 AM |
