| bradtho |
Sep 11 2011, 05:49 PM
Member ![]() ![]() Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
I've read several threads on case splitting and been over the classic "splitting case halves" pictures at least 3 times. I'm pulling on the tranny studs, and not seeing any gap form at all. here's some pictures in case someone is able to spot a bolt that I've missed. I'm avoiding the use of screwdrivers, but what would your next steps be assuming that I haven't in fact missed a bolt.
the big 6 ![]() along the top ![]() down the front (you think the front main seal was leaking?) ![]() the sneaky 2 on the side ![]() the one behind the flywheel ![]() sneaky one below the flywheel and back half of bottom ![]() front half of bottom ![]() |
| McMark |
Sep 17 2011, 08:07 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Pry between the hub and the seal. (IMG:style_emoticons/default/wink.gif)
bradtho yet another case won't split thread Sep 11 2011, 05:49 PM
tomeric914 If you forceably tried to pull the 6 thru case stu... Sep 11 2011, 06:16 PM
bradtho
If you forceably tried to pull the 6 thru case st... Sep 11 2011, 08:39 PM
McMark You can safely apply pressure by wedging a screwdr... Sep 11 2011, 06:47 PM
McMark
You can safely apply pressure by wedging a screwd... Sep 17 2011, 08:02 PM
bradtho
You can safely apply pressure by wedging a screw... Sep 17 2011, 08:04 PM
stugray I use my woodworkers plastic clamps.
You can rever... Sep 11 2011, 07:21 PM
Valy
Hard to say but, in this picture there is one ... Sep 12 2011, 08:20 AM
bradtho
Hard to say but, in this picture there is one ju... Sep 12 2011, 08:44 AM
bradtho weekend again, so I'm back at it. i tapped the... Sep 17 2011, 03:42 PM
McMark I think she's talking about this one... Sep 12 2011, 09:40 AM
Valy
:ag... Sep 12 2011, 11:11 AM
McMark
:a... Sep 12 2011, 02:46 PM
gothspeed As was mentioned it should not have to be forced t... Sep 12 2011, 10:47 AM
r_towle A block of wood resting on a case tab and a good t... Sep 12 2011, 11:18 AM
Cap'n Krusty With one half of the case securely attached to the... Sep 12 2011, 12:14 PM
bradtho
Pry between the hub and the seal. ;)
SUCCESS... Sep 17 2011, 08:56 PM
dlee6204 Good work! :trophy: Sep 17 2011, 09:03 PM
McMark Nice job! Some of them are more 'stuck... Sep 18 2011, 09:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:16 PM |
